7 Replies Latest reply on Aug 6, 2009 5:05 PM by Roulette System Player
    updating bets based on _droptarget
    wwscoper Level 1
      I have another question on my roulette game that I am building.
      The bets for the game are being placed by dragging a chip to a slot on the table. There are six slots, with numbers 1-6, 6-12, 12-18, etc....
      I have a $25 chip and a $5 chip. I am using _droptarget to detect when a chip has been placed on one of the slots. If a $25 chip is placed on "slot1",
      slot1Bet += 25;
      Now the tricky part...if I move the chip from slot1 to another slot before the roulette wheel is spun, I need to change the bets so that "slot1 -=  25" and another slot gets the bet added. I'm calulating the final results by using something like this:
      if (winningNumber<= 6){
      return Number(money) + Number(slot1Bet) - Number(slot2Bet) - Number(slot3Bet) - Number(slot4Bet) - Number(slot5Bet) - Number(slot6Bet);
      Any ideas?
      Thanks!
      P.S. sorry for reposting this, but I thought it better to start a new thread since my last question was answered.
        • 1. Re: updating bets based on _droptarget
          you could define a property of each chip that stores its slot.  when a chip is dropped check its property to see if you need to update a slotbet (ie, the property is defined) and then update its property.
          • 2. Re: updating bets based on _droptarget
            wwscoper Level 1
            Thanks Kglad! I hope your in for another question.
            I have set a property for my chips like this: twentyfiveChip_mc.slot = undefined;
            I have code like this when the chips are dropped on a slot:
            if(twentyfiveChip_mc._droptarget == "/slot1"){
            twentyfiveChip_mc.stopDrag();
            if (twentyfiveChip_mc.slot == undefined){
            slot1Bet += 25;
            } else updateSlotBet();
            twentyfiveChip_mc.slot = 1;
            trace("You have a 25 chip on slot " +twentyfiveChip_mc.slot);
            trace("Slot 1 bet is " + slot1Bet);
               } else if (twentyfiveChip_mc._droptarget == "/slot2"){
               slot2Bet += 25;
            twentyfiveChip_mc.slot = 2;
               trace("Slot two bet is " +slot2Bet);
            I'm trying to figure out what the updateSlotBet function will look like. I'm going to sleep on this one, but if you have an idea...I'd love to hear it!
            Thanks!
            • 3. Re: updating bets based on _droptarget
              i would approach this with some fore-planning.  first, i would have each chip have a value property (how much it's worth), in addition to a slot property to indicate which slot the chip is placed on.  (btw, you do not need to intialize chip.slot=undefined.  chip.slot will be undefined unless you explicitly define it which you're not going to do unless it's dropped on a slot).
              and each slot1,..,slot36,slot0,slot00 i would add to a parent movieclip (say table) and assign it a property storing its slot number (though this can be derived easily using the slot movieclip's _name property and the flash string methods).
              and i would create the initial setup using some parameters to give you more flexibility:
              var chipValA:Array=[1,5,25,100];  // chip values
              var chipNumA:Array=[20,20,20,20];  // number of $1, $5, $25, $100 chips.
              i would create 1 of each of those chips and assign a linkage id:  chip1_ID,chip5_ID,chip25_ID,chip100_ID
              you could then code:
              var dep:Number = 0;
              for(var i:Number=0;i<chipNumA.length;i++){
              for(var j:Number=0;j<chipNumA[i];j++){
              var mc:MovieClip = this.attachMovie("chip"+chipValA[i]+"_ID","chip_"+dep,dep++);
              mc.value=chipValA[i];
              // assign _x and _y properties
              mc.startX=mc._x;
              mc.startY=mc._y;
              mc.onPress=function(){
              this.startDrag();
              mc.onRelease=mc.onReleaseOutside=function(){
              for(mc in table){  // loops through all the slots
              if(typeof(table[mc])=="movieclip"&&table[mc]._parent==table){
              if(eval(this._droptarget)== table[mc]){
              if(table[mc].chip==undefined){
              this._x=table[mc]._x;
              this._y=table[mc]._y;
              this.slot=table[mc].slot;
              table[mc].chip=this;
              } else {
              // this slot already has a chip on it.  decide what to do.  replace previously placed chip, add to slot or return this chip to its startX,startY
              } else {
              this._x=this.startX;
              this._y=this.startY;
              then when your wheel spins you can loop through all the table children like above (to loop through all the slots), to see which have a chip property.  the chip property references the chip(s) placed on that slot and has(have) a value property so you can determine the amount won.
              after each slot's payout is determined, reassign the slot's chip property to undefined.
              if a slot can hold multiple chips, make its slot property an array so you can push chips into the array should there be more than one chip placed on a slot.
              • 4. Re: updating bets based on _droptarget
                wwscoper Level 1
                Thanks Kglad!
                I ended up solving the problem sticking with value and slot properties like you suggested before. Thanks for this other script though. If i have to do something like this again I have a better idea what is involved.
                • 5. Re: updating bets based on _droptarget
                  you're welcome.
                  • 6. Re: updating bets based on _droptarget
                    wwscoper Level 1
                    I don't mean to advertise here, but thought the forum members might like to see the final project that was possible from the great help received here. Thanks everyone!
                    http://www.pediatricaidshivcare.org/casinonight/
