6 Replies Latest reply on May 14, 2009 7:26 AM by Lalit_OSI
    Flex Data Services Issue
    Lalit_OSI
      I have a DWR service created in java and trying to call it from the flex through http service ,but instead of getting the actual result i am getting result as folows:
      //#DWR-REPLY
      if (window.dwr) dwr.engine.remote.handleBatchException({ name:'java.lang.IllegalArgumentException', message:'Failed to find parameter: scriptSessionId' });
      else if (window.parent.dwr) window.parent.dwr.engine.remote.handleBatchException({ name:'java.lang.IllegalArgumentException', message:'Failed to find parameter: scriptSessionId' });
      and on the server side following is the exception :
      20:51:08,307 WARN  [BaseCallHandler] Exception while processing batch
      java.lang.IllegalArgumentException: Failed to find parameter: scriptSessionId
      at org.directwebremoting.dwrp.Batch.extractParameter(Batch.java:91)
      at org.directwebremoting.dwrp.Batch.<init>(Batch.java:59)
      If any solution on calling the DWR services from flex would be graetly apreciated,
      Lalit
