2 Replies Latest reply on May 15, 2009 12:45 AM by seiza13
    making tree using recursion
    seiza13
      ll!
      well, i have some troubles when i copy folders recursively between trees.
      for example if i click on a folder of my tree_1 i want to copy this folder and its fathers
      Tree1
      >A
        >B
          >C
           - C.1
           - C.2
      when i click on folder "C"
      Tree2
      >A2
      >A
        >B
          >C
            -C.1
            -C.2
      can anyone show me some example?
        • 1. Re: making tree using recursion
          _Natasha_ Level 4
          as a very quick example using XML as a dataProvider.
          Note, that you should use XMLListCollection or ArrayCollection to store your data to show changing data. If you use other arrays you should manually change tree.dataProvider = tree.dataProvider to show changes, but all nodes closed so it will be unable to open the tree.
          Hope it's helpful.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:states>
          <mx:State name="alerting">
          <mx:AddChild relativeTo="{newView}" position="before">
          <mx:Label text="hehe"/>
          </mx:AddChild>
          </mx:State>
          </mx:states>
          <mx:Script>
          <![CDATA[
          import mx.utils.ObjectUtil;
          import mx.events.TreeEvent;
          import mx.controls.Alert;
          private var n:int = 1;
          private function onItemOpen(event:TreeEvent):void
          var newItem:XML;
          var itemData:XML = event.item as XML;
          newItem = ObjectUtil.copy(itemData) as XML;
          newItem.@label = newItem.@label + " " + n.toString();
          delete newItem.*; // delete all childs
          var parent:XML = itemData.parent();
          while (parent.childIndex() != -1) // root has -1
          var addNode:XML = ObjectUtil.copy(parent) as XML;
          delete addNode.*;
          addNode.@label = addNode.@label + " " + n.toString(); // add id
          addNode.appendChild(newItem);
          newItem = addNode;
          parent = parent.parent();
          //Alert.show(newItem.toXMLString());
          n++;
          tstData.source[0].appendChild(newItem);
          tstData.refresh();
          </mx:Script>
          <mx:XMLListCollection id="tstData">
          <mx:source>
          <mx:XMLList xmlns="">
          <root>
          <item label="Level1">
          <item label="Level2">
          <item label="Level3">
          <item label="Level4">
          <item label="level5"/>
          </item>
          </item>
          </item>
          </item>
          </root>
          </mx:XMLList>
          </mx:source>
          </mx:XMLListCollection>
          <mx:HBox x="0" y="0" width="100%" height="100%">
          <mx:Tree id="oldView" width="50%" height="100%" showRoot="false" dataProvider="{tstData}" labelField="@label" itemOpen="onItemOpen(event)">
          </mx:Tree>
          </mx:HBox>
          </mx:Application>
          • 2. Re: making tree using recursion
            seiza13 Level 1
            Hi Natacha!
            your example helped me very much
            Thank you a lot!
