6 Replies Latest reply on May 15, 2009 6:49 AM by Peter Grainge
    RH8: JavaHelp (1.1.3) does not display TOC in Windows XP, but only in Vista
    Q-term
      I have the following problem. I have been using RoboHelp for HTML now for a while to generate JavaHelp projects.
      Since I am generating a context-sensitive help and my customer is only able to implement a help project based on JavaHelp 1.1.3, I cannot use JavaHelp 2.0, though there is a whole series of restrictions with JavaHelp 1.1.3.
      With RoboHelp v7, everything worked fine when creating a JavaHelp 1.1.3 project. With RoboHelp v8, however, the TOC is missing in the JavaHelp. It is not displayed. Usually, I am working on my main PC under Windows XP.
      I tried to generate a JavaHelp 1.1.3 version with RH 8 under Vista (which I have on my notebook), and the TOC was displayed. The project source is a Web Help project.
      When I copy the entire project with the generated JAR file to the PC with Windows XP installed, the TOC is not either displayed.
      Is this a known bug or might there be something else with the Java installation that I should consider? As far as I know, there was a similar issue with TOCs and JavaHelp 1.1.3. under RoboHelp X5 long time ago.
      I have Windows XP SP2 installed. Would SP3 probably resolve this problem?
      I appreciate any answer that might help fixing this problem.
      Thanks in advance.
      Best regard,
      Lena
