5 Replies Latest reply on May 14, 2009 6:56 AM by Muzak
    Debugger won't connect using Flex Builder
    davidmxgraph
      Using a clean install of the full flex builder version (not the plugin version), I've created a new Flex Project, configured to run as an AIR application. There are no previous instances of the application running, my Flash version is the debug version and the build is compiled with the debug option. I get:
      Failed to connect; session timed out.
      Ensure that:
        1. You compiled your Flash application with debugging on.
        2. You are running the debugger version of Flash Player.
      My Flex Builder version is 3.0.2, I'm running on vista, JDK 6 update 11 and I've turned off the Windows firewall.
      Any ideas welcome.
      David
