8 Replies Latest reply on May 20, 2009 6:11 AM by கற்பனை (Imagine)
    Change Hyperlinks
    johnBking78
      I have a indesign cs3 file with loads of Hyperlinks and want to replace the first part of that link with another:
      Example:
      Find this:
      http://forums.adobe.com/
      Change to this:
      http://forums.com/
      is there a way to find and change Hyperlinks?
      Thank you
        • 1. Re: Change Hyperlinks
          Olav Martin Kvern Level 3
          Hi jamb71,
          Try something like this:
          var myDestinationURL;
          var myDocument = app.documents.item(0);
          var findWhat = "http//forums.adobe.com";
          var changeTo = http://forums.com";
          if(myDocument.hyperlinkURLDestinations.length > 0){
          for(var myCounter = myDocument.hyperlinkURLDestinations.length -1; myCounter >=0; myCounter--){
            myDestinationURL = myDocument.hyperlinkURLDestinations.item(myCounter).destinationURL;
            if(myDestinationURL.search(findWhat) != -1){
             myDocument.hyperlinkURLDestinations.item(myCounter).destinationURL = myDestinationURL.replace(findWhat, changeTo);
          Ole
          • 2. Re: Change Hyperlinks
            johnBking78 Level 1
            Thanks Ole, that works just fine, it even finds part of an address, which is very handy.
            Many thanks!
            PS: is there anyway to style tables with a script, I can't fine any answers, all I'm after is to add a one cell style to the header row, then a different cell style to the rest of the table?
            is it even possible?
            • 3. Re: Change Hyperlinks
              johnBking78 Level 1
              Olav Kvern was kind enough to help me with this question, which works on most of my links, but some don't see below:
              ..\folder\another\test.pdf
              and change it to:
              ../folder/another/test.pdf
              When I try the script below it will not work? it won't change the backslash for a forward one? can anyone help!
              var findWhat = "..\folder\another\test.pdf";
              var changeTo = "../folder/another/test.pdf";
              Thank you.
              • 4. Re: Change Hyperlinks
                Hi jamb71,
                It's probably because the backslash is a special character in JavaScript strings. To make it appear, you have to "escape" it--which involves (you guessed it) another backslash. Try:
                var findWhat = "..\\folder\\another\\test.pdf";
                Ole
                • 5. Re: Change Hyperlinks
                  johnBking78 Level 1
                  Fantastic that works really well, I do have a lot of different links, is there any way just to find \\ and change to /
                  Although this does not work, but something like this:
                  var findWhat = "\\";
                  var changeTo = "/";
                  if not I could just look for all characters in the alphabet, but this could be the wrong:
                  var findWhat = "\\a";
                  var changeTo = "/a";
                  var findWhat = "\\b";
                  var changeTo = "/b";
                  Thanks again Olav!
                  • 6. Re: Change Hyperlinks
                    கற்பனை (Imagine) Level 3
                    Hi jamb,
                    Use the below replace function...
                    myNewLink = myLinkString.replace ("\\", "/");
                    Nagaraj
                    • 7. Re: Change Hyperlinks
                      johnBking78 Level 1
                      Thank you Nagaraj1983
                      Only thing is I am so new to this, I am unsure how to implement this in a running script?
                      any pointers would be great.
                      Many thanks
                      • 8. Re: Change Hyperlinks
                        Hi jamb,
                        Check the below script .......  In my guess working the script...
                        var changeTo = findWhat.replace (/\\/g,"/");
                        //var changeTo = "../folder/another/test.pdf";
