0 Replies Latest reply on Jan 30, 2011 5:29 AM by Zeno Bokor
    Solutions to common problems
    Zeno Bokor Level 6
      The first thing that you should do if you have any problems whatsoever is to apply the latest Photoshop patch (11.0.2 for CS4/12.0.3 for CS5) and update your video card drivers. If Photoshop starts acting weird then you should also reset your preferences
      Photoshop CS5 issues
      Known Photoshop CS5 issues
      Problem: Photoshop doesn't start, gives (0xc000001d) error.
      Solution: Install the latest patch for Photoshop, link up top.
      Problem: Repousse or 3D features do not work.
      Solution: Make sure that your video card supports OpenGL Drawing and that it is enabled in Preferences->Performance.
      Problem: The Save As dialog box doesn't show up.
      Solution: This happens because your monitor resolution is below the minimum system requirements of 1024x768.
      Problem: When you zoom in using the Scrubby Zoom feature you cannot pan to see the work canvas.
      Solution: It's a known bug, to fix it simply zoom in or out using any of the traditional methods.
      General Photoshop issues
      Problem: Brush cursor is broken up.
      Solution: Update your video card drivers.
      Problem: Photoshop displays weird lines, squares or other artifacts.
      Solution: If updating your video card drivers doesn't help then you will have to disable OpenGL Drawing from Edit->Preferences->Performance.
      Problem: Photoshop doesn't recognize the video card on XP-64.
      Solution: OpenGL drawing is not supported on this platform due to OS and driver issues.
      Problem: Photoshop doesn't recognize the video card (NOT XP-64).
      Solution: The video card driver says that it does not support the minimum requirements for Photoshop.  Check your video card capabilities against the requirements for Photoshop OpenGL use ( http://kb2.adobe.com/cps/404/kb404898.html ).   Updating the video card driver may solve the problem, or you may need to contact the GPU maker to let them know about the problem.
      Problem: Hand Tool is stuck and selecting tools doesn't work.
      Solution: In most cases this can be solved by simply tapping the space bar.
      Problem: Brushes don't work.
      Solution: Move the pen away from your tablet. If that doesn't work then update your tablet drivers.
      Problem: Images look different in Photoshop or the colors aren't rendered correctly.
      Solution: You need to calibrate your monitor with a hardware calibration device or, if you don't have one, with something like Calibrize .
      Problem: Photoshop slows down after using it for prolonged periods of time.
      Solution: Check out this tech note: http://kb2.adobe.com/cps/404/kb404439.html
      Problem: General installation problems.
      Solution: Try running the Adobe Clean Script for CS4/CS5
      Problem: Cannot open Camera Raw files.
      Solution: Check out this tech note: http://kb2.adobe.com/cps/407/kb407110.html
