3 Replies Latest reply on Sep 18, 2008 12:14 PM by ntsiii
    Quering XML
    vikceo
      hie i have an xml file which i can query based on some attribute.. can i also get the results sorted based on some other attribute?
        • 1. Re: Quering XML
          Level 7
          "vikceo" <webforumsuser@macromedia.com> wrote in message
          news:gaqn4o$dd1$1@forums.macromedia.com...
          If you put it in an XMLListCollection, you can sort that.
          • 2. Re: Quering XML
            vikceo Level 1
            so there is no way to query it directly from the xml in the by desired sort attribute?
            • 3. Re: Quering XML
              ntsiii Level 3
              XML does not have a childnode sort function.
              You can "query", that is filter, the nodes based on an attribute value but not sort.
              If you want to hard sort the child nodes, it can be done programatically. Here is an example.
              Tracy
