12 Replies Latest reply on May 14, 2009 12:42 PM by Miggl
    Check if Function Variable is Instanciated
    Miggl Level 1
      How can I check if a function variable is instanciated? I have the following in a custom component:
      [Bindable]
      public var selectionFunction:Function;
      I would now like to check at runtime if anything has been assigned to the selectionFunction variable, i.e. if it has been instanciated with a function. The following methods have failed me so far:
      if (this.selectionFunction is Function)     //failure, type error #1009
      if (this["selectionFunction"] is Function)  //failure, type error #1009
      if (this.selectionFunction != null)         //failure, type error #1009
      if ("selectionFunction" in this)            //failure, type error #1009
      Any ideas on how to achieve this at run-time?
      Thanks!
      -Mike
        • 1. Re: Check if Function Variable is Instanciated
          ATIF FAROOQ Level 3
          hi,
             you can check by this method
          trace(String(selectionFunction)=="null")
          • 2. Re: Check if Function Variable is Instanciated
            Miggl Level 1
            Thanks for the suggestion, but that also resulted in a type error #1009.
            • 3. Re: Check if Function Variable is Instanciated
              _Natasha_ Level 4
              Hi Mike,
              Error description.
              1009Cannot access a property or method of a null object reference.
              So it seems that you this is null.
              In sdk source functions always checks != null.
              • 4. Re: Check if Function Variable is Instanciated
                Michael Borbor Level 4
                Try if
                Sincerely,
                Michael
                • 5. Re: Check if Function Variable is Instanciated
                  Try if(selectionFormula!=null)
                  Sincerely,
                  Michael
                  #1009
                  #1009
                  #1009
                  #1009
                  -Mike
                  • 6. Re: Check if Function Variable is Instanciated
                    Miggl Level 1
                    Perhaps, but I need to be able to make that determination without triggering an error. Triggering an error situation to check properties, objects, or whatever is unacceptable from a programming point of view.
                    Mike
                    • 7. Re: Check if Function Variable is Instanciated
                      ATIF FAROOQ Level 3
                      then problem is not here . You may be doing some wrong assignments some where else in your code.
                      • 8. Re: Check if Function Variable is Instanciated
                        Miggl Level 1
                        Hi Michael,
                        That was one of my original test-scenarios I tried. Also results in an 1009 error.
                        Mike
                        • 9. Re: Check if Function Variable is Instanciated
                          Miggl Level 1
                          Try this on for size:
                          <mx:Application
                               xmlns:mx="http://www.adobe.com/2006/mxml"
                               layout="absolute"
                               creationComplete="initApp()"
                               <mx:Script>
                                    <![CDATA[
                                         import mx.controls.Alert;
                                         private var myFunction     :Function;
                                         private function initApp():void
                                              try
                                                   Alert.show("Start");
                                                   if (this.myFunction != null)
                                                        Alert.show("Function Exists!");
                                                   else
                                                        Alert.show("Function Does Not Exist!");
                                                   Alert.show("End");
                                              catch (error:Error)
                                                   Alert.show("Name: " + error.name + "\nID: " + error.errorID + "\nMessage: " + error.message + "\nStack Trace: " + error.getStackTrace() + "\nError: " + error.toString(), "Failure");
                               </mx:Script>
                          </mx:Application>
                          This example would show that is does work. I'll keep looking.
                          Thanks!
                          Mike
                          • 10. Re: Check if Function Variable is Instanciated
                            M. Regert
                            function != null seems to work for me:
                            <mx:Application
                            xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
                            <mx:Script>
                            <![CDATA[
                            import
                            mx.controls.Alert;
                            Bindable
                            public var
                            private function check():void
                            if (selectionFunction != null
                            Alert.show(
                            "Function is defined", "Success"
                            else
                            Alert.show(
                            "Function is NOT defined", "Failure"
                            private function foo():void
                            trace("some dummy function"
                            private function onToggle(event:Event):void
                            var toggle:CheckBox = event.currentTarget as
                            CheckBox;
                            if
                            (toggle.selected) {
                            selectionFunction = foo;
                            else
                            selectionFunction =
                            null
                            check();
                            </mx:Script>
                            <mx:Panel width="400" height="300" layout="absolute"
                            <mx:CheckBox id="cbToggle" label="Assign value to function variable" change="onToggle(event)" horizontalCenter="0" verticalCenter="0"
                            </mx:Panel>
                            • 11. Re: Check if Function Variable is Instanciated
                              ATIF FAROOQ Level 3
                              i just executed your code it works fine as it is . it never goes to catch statement.
                              • 12. Re: Check if Function Variable is Instanciated
                                Miggl Level 1
                                Atif, you're absolutely right.
                                Thanks to everyone for bearing with me. It took my a while to realize what Atif said (that it must be something else in my code). In fact, another if statement had exactly the same issue, and was erroring out there. After rectifying that, everything worked as expected.
                                Thanks again! I doled out what what experience points I could (wish I could have given everyone helpful on this, but there were only 2).
                                -Mike
