4 Replies Latest reply on May 14, 2009 3:23 PM by M. Regert
    Problem with module loading another module
    M. Regert
      I have run into what appears to be a bug in Adobe Flex 3.3, but would like others opinion.  I have a simple application which loads a module.
      If a user checks a box, then the module loads a submodule and calls a funtion in that submodule which modifies the UI slightly.
      It really is simple code, but not easy to explain, so bear with me on this :-)  All code is attached.  Rename from *.txt to *.mxml.
      I have added an event listener to the submodule loader for the ModuleEvent.READY event so that I can call a function in it once it is loaded (the function modifies the UI):
      private function onModuleReady(event:Event):void
           Alert.show(
      "Module load successful", "Success");
           if (loader2.child is SubModule) {
                var module:SubModule = loader2.child as SubModule;
                module.createCompleteHandler();
                module.modifyUI(pnlMain);
      else {
                Alert.show(
      "loader is NOT SubModule", "Failure");
      Stepping through the debugger, loader2.child IS INDEED a SubModule Class, yet I consistantly step into the else clause.  As I debugged this, I added a similar event listener for the READY even on the loading of the first module.  By just defining a new function in the main module, this code now works.  I don't have to actually call that function, just define it, meaning that if I comment out the entire function onModuleReady (the one defined in the main application that is just printing out a trace), I get the error stated above.
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="createCompleteHandler()"
      <mx:Script>
      <![CDATA[
      import
      MainModule;
      import
      mx.events.ModuleEvent;
      private function createCompleteHandler():void
      loader.url =
      "MainModule.swf"
      // loader.addEventListener(ModuleEvent.READY, onModuleReady);
      loader.loadModule();
      if (loader.child is
      MainModule) {
      trace("here"
      Please try the attached code, and try running it with the function onModuleReady implelented in the Application body and with it removed.  Why would defining a function that is never called for the first module affect the second module?
