14 Replies Latest reply on May 15, 2009 6:42 AM by rcanulla
    Can't access text properties in AS3. only in MXML
    rcanulla
      Please help, I want to access the text property via as3. The code below.
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="listService.send()" height="100%" width="555" backgroundAlpha="0.0">
      <mx:Script>
          <![CDATA[
              import mx.collections.XMLListCollection;
              import mx.rpc.events.ResultEvent;
              namespace ink = "http://www.inktomi.com/";
              use namespace ink;
              [Bindable] private var xmlList:XMLList;
              [Bindable] private var listCollection:XMLListCollection;
              [Bindable] private var listData:XML;
              [Bindable] public var serviceURL:String = "http://boss.yahooapis.com/ysearch/news/v1/";
              [Bindable] public var searchFor:String = "biotechnology%20AND%20biotech";
              private const PROXY:String = "http://localhost/employeePhoneDesktop/src/php/proxy.php?url=";
              private const APIID:String = "###################";
              private const PARAMS:String = "&format=xml&orderby=date";
              private function resultHandler(e:ResultEvent):void {
                  listData = e.result as XML;
                  // add the imems to an XMLList and XMLListCollection
                  // so that they can be used with the repeater class
                  // and update automatically
                  xmlList = e.result.resultset_news.result as XMLList;
                  listCollection = new XMLListCollection(xmlList);
                  setData();
              private function setData():void {
                  itemRepeater.dataProvider = listCollection;
      ------>  abstract.text = "test in AS3";
                  abstract.visible = false;
      </mx:Script>
          <mx:HTTPService id="listService" url="{serviceURL + searchFor + APIID + PARAMS}" result="resultHandler(event)" resultFormat="e4x"/>
          <mx:VBox>
              <mx:Repeater id="itemRepeater">
                  <mx:VBox verticalGap="0" x="10" y="10">
                      <mx:LinkButton id="itemTitle" label="{itemRepeater.currentItem.title}" width="400"/>
                      <mx:Label text="{itemRepeater.currentItem.source + ' | ' + itemRepeater.currentItem.date}"/>
        ---->           <mx:Text id="abstract" text="test in MXML" width="400" visible="true" />
                  </mx:VBox>
              </mx:Repeater>
          </mx:VBox>
      </mx:Canvas>
        • 1. Re: Can't access text properties in AS3. only in MXML
          rcanulla Level 1
          I can access this info anywhere outside of the Repeater. Any thoughs?
          • 2. Re: Can't access text properties in AS3. only in MXML
            Michael Borbor Level 4
            Hi there, what property do you want to access?
            A small suggestion next time that you post your code could you please clcik on the icon >> , then select Syntax Highlighting and choose Java. Once you do this your code would look like this:
            private function init():void
                                stage.displayState=StageDisplayState.FULL_SCREEN_INTERACTIVE;
                                if (Selected==null){
                                     trace("Show");
            • 3. Re: Can't access text properties in AS3. only in MXML
              rcanulla Level 1
              Sorry! I was looking for something like that!
              I am trying to set my text properties in the setData() rather than in MXML. I think it will give me cleaner code.  Also, I want to have the abstract text set to none until a user clicks on the linkButton (title).
              <mx:Script>
                   <![CDATA[
                        use namespace ink;
                        private const APIID:String = "###########";
                             setData();
                             //abstract.text = "test in AS3";
                             //abstract.visible = false;
              </mx:Script>
                   <mx:VBox>
                                  <mx:LinkButton id="itemTitle" label="{itemRepeater.currentItem.title}" width="400" click="abstract.text='hey now i got it'"/>
                                  <mx:Label id="itemInfo" text="{itemRepeater.currentItem.source + ' | ' + itemRepeater.currentItem.date}"/>
                                  <mx:Text id="abstract" text="{itemRepeater.currentItem.abstract}" width="400" visible="true" />
                             </mx:VBox>
                        </mx:Repeater>
                   </mx:VBox>
              </mx:Canvas>
              • 4. Re: Can't access text properties in AS3. only in MXML
                I see , you can't do that in that way. Why? Because the repeater is created and render once your app is launch in the browser.
                To accomplish what you want you'll have to code the VBox and the Repeater using AS and not MXML.
                • 5. Re: Can't access text properties in AS3. only in MXML
                  rcanulla Level 1
                  Thank you sir. Can you point me in the right direction with regards to how I would proceed in AS?
                  • 6. Re: Can't access text properties in AS3. only in MXML
                    You could do something like this:
                    private function createLayout():void{
                                        var expenses:ArrayCollection = new ArrayCollection([
                                             {Month:"Jan", Profit:2000, Expenses:120, Amount:45},
                                             {Month:"Feb", Profit:1000, Expenses:200, Amount:60},
                                             {Month:"Mar", Profit:1500, Expenses:500, Amount:30}
                                        var myHbox:HBox=new HBox();
                                        var myText:Text=new Text();
                                        for(var a:Number=0;a<expenses.length;a++){
                                             myText=new Text()
                                             myText.text=expenses.getItemAt(a).Month;
                                             myHbox.addChild(myText);
                                        myHbox.percentWidth=80;
                                        addChild(myHbox);
                    Trigger by a button or any other action that you need
                    <mx:Button label="Click me" click="createLayout()" />
                    • 7. Re: Can't access text properties in AS3. only in MXML
                      rcanulla Level 1
                      Thanks! Can I use this with an an XMLListCollection? Or do I need to push the items into an arayCollection?
                      Thanks again for all of your help!
                      • 8. Re: Can't access text properties in AS3. only in MXML
                        You can use an XMLListCollection too.
                        You're welcome.
                        • 9. Re: Can't access text properties in AS3. only in MXML
                          rcanulla Level 1
                          So i did as you wrote, but am getting only 1 result. When I debug, I can see that the listCollection contains 10 items. Thoughts?
                                    private function createLayout():void {
                                         var vBox:VBox = new VBox();
                                         var hBox:HBox = new HBox();
                                         var titleText:Text = new Text();
                                         var itemInfo:Text = new Text();
                                         var abstract:TextArea = new TextArea();
                                         var archive:CheckBox = new CheckBox();
                                         for(var i:Number=0; i<listCollection.length; i++){
                                              titleText.text = listCollection.getItemAt(i).title;
                                              vBox.addChild(titleText);
                                              itemInfo.text = listCollection.getItemAt(i).source + " | " + listCollection.getItemAt(i).date;
                                              vBox.addChild(itemInfo);
                                         hBox.percentWidth = 80;
                                         hBox.percentHeight = 80;
                                         addChild(vBox);
                          Also, can I use CSS formatters to format in AS3?
                          • 10. Re: Can't access text properties in AS3. only in MXML
                            rcanulla Level 1
                            I should probably note that I get the last (oldest) item from my listCollection. I thought that was a bit odd (maybe not).
                            • 11. Re: Can't access text properties in AS3. only in MXML
                              Could you post the XML file that you're using?
                              • 12. Re: Can't access text properties in AS3. only in MXML
                                rcanulla Level 1
                                I am getting it from yahoo boss API.(the public api for news search)
                                <ysearchresponse responsecode="200" xmlns="http://www.inktomi.com/">
                                  <nextpage>
                                    <![CDATA[/ysearch/news/v1/biotechnology%20AND%20biotech?count=10&appid=&orderby=date&format=xml&start=10]]>
                                  </nextpage>
                                  <resultset_news count="10" start="0" totalhits="122" deephits="122">
                                    <result>
                                      <abstract>
                                        President Obama is "right to push for [health care] reform now, despite calls to postpone efforts solely on the economic recovery," a Philadelphia Inquirer editorial states.
                                      </abstract>
                                      <clickurl>
                                        http://lrd.yahooapis.com/_ylc=X3oDMTVjZGJ2c21rBF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA3pGU3g1R0tJY3JwUkdqcVQ3SkNxcVpaaDJBOTZXa29NdXBjQUFPanA-/SIG=13usgm8rr/**http%3A//www.news-medical.net/news/2009/05/14/Editorial-says-Obama-is-e2809cright-to-push-for-health-care-reforme2809d.aspx
                                      </clickurl>
                                      <date>
                                        2009/05/15
                                      </date>
                                      <language>
                                        english
                                      </language>
                                      <source>
                                        News-Medical-Net
                                      </source>
                                      <sourceurl>
                                        http://www.news-medical.net/
                                      </sourceurl>
                                      <time>
                                        00:39:35
                                      </time>
                                      <title>
                                        Editorial says, Obama is “right to push for health care reform”
                                      </title>
                                      <url>
                                        http://www.news-medical.net/news/2009/05/14/Editorial-says-Obama-is-e2809cright-to-push-for-health-care-reforme2809d.aspx
                                      </url>
                                    </result>
                                    <result>
                                      <abstract>
                                        By Bill Berkrot
                                      </abstract>
                                      <clickurl>
                                        http://lrd.yahooapis.com/_ylc=X3oDMTVjZGJ2c21rBF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA3pGU3g1R0tJY3JwUkdqcVQ3SkNxcVpaaDJBOTZXa29NdXBjQUFPanA-/SIG=137ejnkf3/**http%3A//www.iii.co.uk/news/%3Ftype=afxnews%26articleid=7322383%26subject=companies%26action=article
                                      </clickurl>
                                      <date>
                                        2009/05/14
                                      </date>
                                      <language>
                                        english
                                      </language>
                                      <source>
                                        Interactive Investor
                                      </source>
                                      <sourceurl>
                                        http://www.iii.co.uk/
                                      </sourceurl>
                                      <time>
                                        22:37:09
                                      </time>
                                      <title>
                                        (AFX UK Focus) 2009-05-14 23:15 UPDATE 1-Tarceva helps keep lung cancer from worsening-study
                                      </title>
                                      <url>
                                        http://www.iii.co.uk/news/?type=afxnews&amp;articleid=7322383&amp;subject=companies&amp;action=article
                                      </url>
                                    </result>
                                    <result>
                                      <abstract>
                                        <![CDATA[The American Civil Liberties Union action in filing a lawsuit yesterday against Myriad Genetics is going to lead to one of the most important legal battles in the history of biotechnology, asserts Genetic Engineering & Biotechnology News (GEN). The ACLU charged that the patenting of two human genes linked to breast and ovarian cancer will inhibit medical research. The organization also claims ...]]>
                                      </abstract>
                                      <clickurl>
                                        http://lrd.yahooapis.com/_ylc=X3oDMTVjZGJ2c21rBF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA3pGU3g1R0tJY3JwUkdqcVQ3SkNxcVpaaDJBOTZXa29NdXBjQUFPanA-/SIG=11epq02rp/**http%3A//www.physorg.com/news161542716.html
                                      </clickurl>
                                      <date>
                                        2009/05/14
                                      </date>
                                      <language>
                                        english
                                      </language>
                                      <source>
                                        PhysOrg
                                      </source>
                                      <sourceurl>
                                        http://www.physorg.com/
                                      </sourceurl>
                                      <time>
                                        22:07:23
                                      </time>
                                      <title>
                                        ACLU -- Myriad Genetics lawsuit will become landmark case
                                      </title>
                                      <url>
                                        http://www.physorg.com/news161542716.html
                                      </url>
                                    </result>
                                    <result>
                                      <abstract>
                                        <![CDATA[( Mary Ann Liebert, Inc./Genetic Engineering News ) The American Civil Liberties Union action in filing a lawsuit yesterday against Myriad Genetics is going to lead to one of the most important legal battles in the history of biotechnology, asserts Genetic Engineering & Biotechnology News. The ACLU charged that the patenting of two human genes linked to breast and ovarian cancer will inhibit ...]]>
                                      </abstract>
                                      <clickurl>
                                        http://lrd.yahooapis.com/_ylc=X3oDMTVjZGJ2c21rBF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA3pGU3g1R0tJY3JwUkdqcVQ3SkNxcVpaaDJBOTZXa29NdXBjQUFPanA-/SIG=126eo9o3d/**http%3A//www.eurekalert.org/pub_releases/2009-05/mali-agl051409.php
                                      </clickurl>
                                      <date>
                                        2009/05/14
                                      </date>
                                      <language>
                                        english
                                      </language>
                                      <source>
                                        EurekAlert!
                                      </source>
                                      <sourceurl>
                                        http://www.eurekalert.org/
                                      </sourceurl>
                                      <time>
                                        21:53:26
                                      </time>
                                      <title>
                                      </title>
                                      <url>
                                        http://www.eurekalert.org/pub_releases/2009-05/mali-agl051409.php
                                      </url>
                                    </result>
                                    <result>
                                      <abstract>
                                        Thornburg Core Growth Fund is outdoing its peers and the U.S. market so far this year, but manager Alex Motola would prefer that stocks hadn’t run up so far, so fast.
                                      </abstract>
                                      <clickurl>
                                        http://lrd.yahooapis.com/_ylc=X3oDMTVjZGJ2c21rBF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA3pGU3g1R0tJY3JwUkdqcVQ3SkNxcVpaaDJBOTZXa29NdXBjQUFPanA-/SIG=13e2var20/**http%3A//www.marketwatch.com/enf/rss.asp%3Fguid=%257B3976B0E2-6447-495E-9D35-37F2098C04DB%257D%26siteid=rss
                                      </clickurl>
                                      <date>
                                        2009/05/14
                                      </date>
                                      <language>
                                        english
                                      </language>
                                      <source>
                                        Market Watch
                                      </source>
                                      <sourceurl>
                                        http://www.marketwatch.com/
                                      </sourceurl>
                                      <time>
                                        21:51:01
                                      </time>
                                      <title>
                                        The Stockpickers: Fund manager eyes FLIR Systems, Alexion, Equinix
                                      </title>
                                      <url>
                                        http://www.marketwatch.com/enf/rss.asp?guid=%7B3976B0E2-6447-495E-9D35-37F2098C04DB%7D&amp;siteid=rss
                                      </url>
                                    </result>
                                    <result>
                                      <abstract>
                                        WINNIPEG, MANITOBA--(Marketwire - May 14, 2009) - Kane Biotech Inc. (TSX VENTURE:KNE) (the "Company"), a biotechnology company engaged in the development of products that prevent and disperse microbial biofilms, has closed its previously announced private placement offering (the "Offering") with aggregate gross proceeds to the Company of $250,000 from the sale of 3,571,429 units ("Units") at a ...
                                      </abstract>
                                      <clickurl>
                                        http://lrd.yahooapis.com/_ylc=X3oDMTVjZGJ2c21rBF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA3pGU3g1R0tJY3JwUkdqcVQ3SkNxcVpaaDJBOTZXa29NdXBjQUFPanA-/SIG=127a0beqs/**http%3A//www.marketwire.com/mw/release.do%3Fid=990128%26sourceType=3
                                      </clickurl>
                                      <date>
                                        2009/05/14
                                      </date>
                                      <language>
                                        english
                                      </language>
                                      <source>
                                        Marketwire
                                      </source>
                                      <sourceurl>
                                        http://www.marketwire.com/
                                      </sourceurl>
                                      <time>
                                        21:50:53
                                      </time>
                                      <title>
                                        Kane Biotech Announces Closing of Private Placement Offering
                                      </title>
                                      <url>
                                        http://www.marketwire.com/mw/release.do?id=990128&amp;sourceType=3
                                      </url>
                                    </result>
                                    <result>
                                      <abstract>
                                        The organizers of the annual biotechnology trade show at Progress Corporate Park were fully prepared to scale back this year's event in light of the sour economy.
                                      </abstract>
                                      <clickurl>
                                        http://lrd.yahooapis.com/_ylc=X3oDMTVjZGJ2c21rBF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA3pGU3g1R0tJY3JwUkdqcVQ3SkNxcVpaaDJBOTZXa29NdXBjQUFPanA-/SIG=12ede36kg/**http%3A//www.gainesville.com/article/20090513/articles/905131010%26tc=yahoo
                                      </clickurl>
                                      <date>
                                        2009/05/14
                                      </date>
                                      <language>
                                        english
                                      </language>
                                      <source>
                                        The Gainesville Sun
                                      </source>
                                      <sourceurl>
                                        http://www.gainesville.com/
                                      </sourceurl>
                                      <time>
                                        21:16:50
                                      </time>
                                      <title>
                                        Biotech trade show draws strong turnout
                                      </title>
                                      <url>
                                        http://www.gainesville.com/article/20090513/articles/905131010&amp;tc=yahoo
                                      </url>
                                    </result>
                                    <result>
                                      <abstract>
                                        VANCOUVER, BRITISH COLUMBIA--(Marketwire - May 14, 2009) - Allon Therapeutics Inc. (TSX:NPC) reported today in its First Quarter 2009 operating results that the Company is on track to achieve its 2009 milestones, including completing a partnership with a major pharmaceutical company and advancing the clinical development of lead neuroprotective product candidate davunetide intranasal (AL-108) ...
                                      </abstract>
                                      <clickurl>
                                        http://lrd.yahooapis.com/_ylc=X3oDMTVjZGJ2c21rBF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA3pGU3g1R0tJY3JwUkdqcVQ3SkNxcVpaaDJBOTZXa29NdXBjQUFPanA-/SIG=1272cla75/**http%3A//www.marketwire.com/mw/release.do%3Fid=990087%26sourceType=3
                                      </clickurl>
                                      <date>
                                        2009/05/14
                                      </date>
                                      <language>
                                        english
                                      </language>
                                      <source>
                                        Marketwire
                                      </source>
                                      <sourceurl>
                                      </sourceurl>
                                      <tim...
                                     listCollection
                                <result xmlns="http://www.inktomi.com/">
                                  <abstract>President Obama is "right to push for [health care] reform now, despite calls to postpone efforts solely on the economic recovery," a Philadelphia Inquirer editorial states.</abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=13usgm8rr/**http%3A//www.news-medical.net/news/2009/05/14/Editorial-says-Obama-is-e2809cright-to-push-for-health-care-reforme2809d.aspx</clickurl>
                                  <date>2009/05/15</date>
                                  <language>english</language>
                                  <source>News-Medical-Net</source>
                                  <sourceurl>http://www.news-medical.net/</sourceurl>
                                  <time>00:39:35</time>
                                  <title>Editorial says, Obama is “right to push for health care reform”</title>
                                  <url>http://www.news-medical.net/news/2009/05/14/Editorial-says-Obama-is-e2809cright-to-push-for-health-care-reforme2809d.aspx</url>
                                </result>
                                  <abstract>By Bill Berkrot</abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=137ejnkf3/**http%3A//www.iii.co.uk/news/%3Ftype=afxnews%26articleid=7322383%26subject=companies%26action=article</clickurl>
                                  <date>2009/05/14</date>
                                  <source>Interactive Investor</source>
                                  <sourceurl>http://www.iii.co.uk/</sourceurl>
                                  <time>22:37:09</time>
                                  <title>(AFX UK Focus) 2009-05-14 23:15 UPDATE 1-Tarceva helps keep lung cancer from worsening-study</title>
                                  <url>http://www.iii.co.uk/news/?type=afxnews&amp;articleid=7322383&amp;subject=companies&amp;action=article</url>
                                </result>
                                  <abstract><![CDATA[The American Civil Liberties Union action in filing a lawsuit yesterday against Myriad Genetics is going to lead to one of the most important legal battles in the history of biotechnology, asserts Genetic Engineering & Biotechnology News (GEN). The ACLU charged that the patenting of two human genes linked to breast and ovarian cancer will inhibit medical research. The organization also claims ...]]></abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=11epq02rp/**http%3A//www.physorg.com/news161542716.html</clickurl>
                                  <source>PhysOrg</source>
                                  <sourceurl>http://www.physorg.com/</sourceurl>
                                  <time>22:07:23</time>
                                  <title>ACLU -- Myriad Genetics lawsuit will become landmark case</title>
                                  <url>http://www.physorg.com/news161542716.html</url>
                                </result>
                                  <abstract><![CDATA[( Mary Ann Liebert, Inc./Genetic Engineering News ) The American Civil Liberties Union action in filing a lawsuit yesterday against Myriad Genetics is going to lead to one of the most important legal battles in the history of biotechnology, asserts Genetic Engineering & Biotechnology News. The ACLU charged that the patenting of two human genes linked to breast and ovarian cancer will inhibit ...]]></abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=126eo9o3d/**http%3A//www.eurekalert.org/pub_releases/2009-05/mali-agl051409.php</clickurl>
                                  <source>EurekAlert!</source>
                                  <sourceurl>http://www.eurekalert.org/</sourceurl>
                                  <time>21:53:26</time>
                                  <url>http://www.eurekalert.org/pub_releases/2009-05/mali-agl051409.php</url>
                                </result>
                                  <abstract>Thornburg Core Growth Fund is outdoing its peers and the U.S. market so far this year, but manager Alex Motola would prefer that stocks hadn’t run up so far, so fast.</abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=13e2var20/**http%3A//www.marketwatch.com/enf/rss.asp%3Fguid=%257B3976B0E2-6447-495E-9D35-37F2098C04DB%257D%26siteid=rss</clickurl>
                                  <source>Market Watch</source>
                                  <sourceurl>http://www.marketwatch.com/</sourceurl>
                                  <time>21:51:01</time>
                                  <title>The Stockpickers: Fund manager eyes FLIR Systems, Alexion, Equinix</title>
                                  <url>http://www.marketwatch.com/enf/rss.asp?guid=%7B3976B0E2-6447-495E-9D35-37F2098C04DB%7D&amp;siteid=rss</url>
                                </result>
                                  <abstract>WINNIPEG, MANITOBA--(Marketwire - May 14, 2009) - Kane Biotech Inc. (TSX VENTURE:KNE) (the "Company"), a biotechnology company engaged in the development of products that prevent and disperse microbial biofilms, has closed its previously announced private placement offering (the "Offering") with aggregate gross proceeds to the Company of $250,000 from the sale of 3,571,429 units ("Units") at a ...</abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=127a0beqs/**http%3A//www.marketwire.com/mw/release.do%3Fid=990128%26sourceType=3</clickurl>
                                  <source>Marketwire</source>
                                  <sourceurl>http://www.marketwire.com/</sourceurl>
                                  <time>21:50:53</time>
                                  <title>Kane Biotech Announces Closing of Private Placement Offering</title>
                                  <url>http://www.marketwire.com/mw/release.do?id=990128&amp;sourceType=3</url>
                                </result>
                                  <abstract>The organizers of the annual biotechnology trade show at Progress Corporate Park were fully prepared to scale back this year's event in light of the sour economy.</abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=12ede36kg/**http%3A//www.gainesville.com/article/20090513/articles/905131010%26tc=yahoo</clickurl>
                                  <source>The Gainesville Sun</source>
                                  <sourceurl>http://www.gainesville.com/</sourceurl>
                                  <time>21:16:50</time>
                                  <title>Biotech trade show draws strong turnout</title>
                                  <url>http://www.gainesville.com/article/20090513/articles/905131010&amp;tc=yahoo</url>
                                </result>
                                  <abstract>VANCOUVER, BRITISH COLUMBIA--(Marketwire - May 14, 2009) - Allon Therapeutics Inc. (TSX:NPC) reported today in its First Quarter 2009 operating results that the Company is on track to achieve its 2009 milestones, including completing a partnership with a major pharmaceutical company and advancing the clinical development of lead neuroprotective product candidate davunetide intranasal (AL-108) ...</abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=1272cla75/**http%3A//www.marketwire.com/mw/release.do%3Fid=990087%26sourceType=3</clickurl>
                                  <time>21:06:17</time>
                                  <title>Allon Therapeutics Releases First Quarter Operating Results</title>
                                  <url>http://www.marketwire.com/mw/release.do?id=990087&amp;sourceType=3</url>
                                </result>
                                  <abstract>Commercial crops of biotech sugarcane are one step closer to becoming a reality in Australia through new and improved genetic transformation technologies.</abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=139iihgnm/**http%3A//nqr.farmonline.com.au/news/state/sugar/general/gm-cane-one-step-closer/1511778.aspx%3Fsrc=rss</clickurl>
                                  <source>North Queensland Register</source>
                                  <sourceurl>http://nqr.farmonline.com.au/</sourceurl>
                                  <time>19:04:06</time>
                                  <title>GM cane one step closer</title>
                                  <url>http://nqr.farmonline.com.au/news/state/sugar/general/gm-cane-one-step-closer/1511778.aspx?src=rss</url>
                                </result>
                                  <abstract>NEW YORK (GenomeWeb News) — The Minnesota State Legislature has approved $16 million in funding for a biomedical research partnership between the University of Minnesota and the Mayo Foundation.</abstract>
                                  <clickurl>http://lrd.yahooapis.com/_ylc=X3oDMTVjdG04ZXZ1BF9TAzIwMjMxNTI3MDIEYXBwaWQDWGpiSkhFX1YzNEguNldqRmdXSjBEUlJpVUdWSHVwRTJMWkFKM1o1Nnpmc04uT2pPS2VrZmNVcTZDR3VUTkdQc0gzTS0EY2xpZW50A2Jvc3MEc2VydmljZQNCT1NTBHNsawN0aXRsZQRzcmNwdmlkA1VDNU9NbUtJY3JybzRJZThoSEtpcjVjLjJBOTZXa29NdmIwQURSYk0-/SIG=12ijqf36u/**http%3A//www.genomeweb.com/minnesota-senate-passes-16m-medical-genomics-biotech</clickurl>
                                  <source>GenomeWeb News</source>
                                  <sourceurl>http://www.genomeweb.com/</sourceurl>
                                  <time>18:48:03</time>
                                  <title>Minnesota Senate Passes $16M for Medical Genomics, Biotech</title>
                                  <url>http://www.genomeweb.com/minnesota-senate-passes-16m-medical-genomics-biotech</url>
                                </result>
                                • 13. Re: Can't access text properties in AS3. only in MXML
                                  Edit your last message and post the values that contains listCollection.
