2 Replies Latest reply on May 15, 2009 6:39 AM by Cesare Rocchi
    Initial Window
    Saka Nurudeen
      Hi everybody!
      I would like to know how to make an initial
      window described in application.xml
      centered in the screen whatever be dimensions
      of screen.
      Please help.
        • 1. Re: Initial Window
          James Whittaker
          Yes easily you can do the following on applicationComplete:
          nativeWindow.x = (Capabilities.screenResolutionX - DEFAULT_WIDTH) / 2;
          nativeWindow.y = (Capabilities.screenResolutionY - DEFAULT_HEIGHT) / 2;
          That should center your initial window.
          • 2. Re: Initial Window
            Cesare Rocchi Level 2
            You have to set it via code, not in the application.xml
            add a listener to the creation complete event
            <mx:WindowedApplication ... creationComplete="creationComplete()" />
            then set x and y like this:
            private function creationComplete():void {
                 nativeWindow.x = x;
                 nativeWindow.y = y;
            Of course you need to do some calculation to find out monitor's resolution (by means of flash.desktop.Capabilities)
