0 Replies Latest reply on May 15, 2009 5:37 AM by wgb14
    Combination question
    wgb14 Level 1
      Hi all
      I wonder if someone can help me with this.
      I have an XML database in the following format:
      -- Main Questions (Level0)
      Q1
      Q2
      Q3
      Q4
      Each of these questions load another set of questions as follows: (Level1)
      <subQ>SubQ1
                    SubQ2
                     SubQ3
                     SubQ4</SubQ>
      Once the user clicks on any of the subquestions, the question is gone and the others rewritten. For example, if the user clicks on SubQ1 the output is as follows: (level2)
      SubQ2 (re-written)
      SubQ3(re-written)
      SubQ4(re-written)
      Or of the user clicks on SubQ2 the output should be as follows:
      SubQ1(re-written)
      SubQ3(re-written)
      SubQ4(re-written)
      The re-written questions will be specified in the XML databases as follows:
      <q1> SubQ1(re-written)</q2>
      <q2>SubQ2(re-written)</q2>
      <q3>SubQ3(re-written)</q3>
      <q4>SubQ4(re-written)</q4>
      So far my code is as follows:
      global
      level1,gmain
      on
      mouseDown (me)
      pointClicked =
      _mouse.mouseLoc
      thisSprite =
      sprite(me.spriteNum)
      currentMember = thisSprite.
      member
      lineNum = thisSprite.
      pointToLine(pointClicked)
      lineText = currentMember.
      line[lineNum]
      -- level 0 (Main Questions)
      If
      level1 = VOID and lineN)um = 1 then
      member
      ("container").text = gmain[1].Architecture.MainQuestions["!CHARDATA"]
      level1=
      "a"
         else
      -- level1 (Sub Questions of main questions)
      if
      level1 = "a" AND lineNum = 1 then
      member
      ("container").text = gmain[1].Architecture.SubQuestions1["!CHARDATA"] --the subquestions of question1
      level1=
      "two"
      else
      if
      level1 = "b" AND lineNum = 1 then
      member
      ("container").text = gmain[1].Architecture.Q2["!CHARDATA"] & gmain[1].Architecture.Q3["!CHARDATA"] & & gmain[1].Architecture.Q4["!CHARDATA"]
      level1= "three"
      end if
      end if
      end if
      end
      Going from the main questions to the subquestions (level1=VOID -> Level1="a") is easy. However, When the user clicks on any of the subquestions (and given that he can click only one question/time) its extremely tedious to write all the combinations by hand. For example, if the subquestions are 4 the last part of the above code should read as follows. Since we want the clicked question eliminated, we end up with 4 combinations of three numbers/questions.
      if level1 = "b" AND lineNum = 1 then
      member ("container").text = gmain[1].Architecture.Q2["!CHARDATA"] & gmain[1].Architecture.Q3["!CHARDATA"] & gmain[1].Architecture.Q4["!CHARDATA"]
      if level1 = "b" AND lineNum = 2 then
      member ("container").text = gmain[1].Architecture.Q1["!CHARDATA"] & gmain[1].Architecture.Q3["!CHARDATA"] &gmain[1].Architecture.Q4["!CHARDATA"]
      combination = "two"
      if level1 = "b" AND lineNum = 3 then
      member ("container").text = gmain[1].Architecture.Q1["!CHARDATA"] & gmain[1].Architecture.Q2["!CHARDATA"] & gmain[1].Architecture.Q4["!CHARDATA"]
      combination = "three"
      if level1 = "b" AND lineNum = 4 then
      member ("container").text = gmain[1].Architecture.Q1["!CHARDATA"] & gmain[1].Architecture.Q2["!CHARDATA"] & & gmain[1].Architecture.Q3["!CHARDATA"]
      If you want to go one level down you will end up with 6 combinations (2 x 2 x 2) of numbers/questions as follows
      if level1 = "c" AND lineNum = 1 then
      member ("container").text = gmain[1].Architecture.Q3_1["!CHARDATA"] & gmain[1].Architecture.Q4_1["!CHARDATA"]
      if level1 = "c" AND lineNum = 2 then
      member ("container").text = gmain[1].Architecture.Q2_1["!CHARDATA"] & gmain[1].Architecture.Q4_1["!CHARDATA"]
      if level1 = "c" AND lineNum = 3 then
      member ("container").text = gmain[1].Architecture.Q2_1["!CHARDATA"] & gmain[1].Architecture.Q3_1["!CHARDATA"]
      if level1 = "c" AND lineNum = 2 AND combination = "two" then
      member ("container").text = gmain[1].Architecture.Q1_1["!CHARDATA"] &gmain[1].Architecture.Q4_1["!CHARDATA"]
      if level1 = "c" AND lineNum = 3 AND combination = "two" then
      member ("container").text = gmain[1].Architecture.Q1_1["!CHARDATA"] &gmain[1].Architecture.Q3_1["!CHARDATA"]
      if level1 = "c" AND lineNum = 3 AND combination = "three" then
      As this is a rather sloppy way of writing code is there any other way to do it?
      Many thanks for any help!!!
