0 Replies Latest reply on May 15, 2009 3:15 PM by jezzthisisfull
    Quick AS3 conversion questions...
    jezzthisisfull Level 1
      Hi, I'm trying to convert an old Flash file to AS3...is there a way to search/replace action script throughout a document, so that for instance, stop() could be replaced with flash.display.MovieClip.stop() wherever it occurs, as a kind of batch opperation?
      Also, is this code AS3 compatible?
      flash.ui.Mouse.hide();
      logo_cursor_mc.flash.events.MouseEvent.MOUSE_MOVE = function() {
          this._x = _xmouse;
          this._y = _ymouse;
          flash.events.TimerEvent.updateAfterEvent();
      Finally...this code is apparently assigned to a button.  Would you mind pointing me in the right direction as to how to covert this code to AS3?  Do I need to name the button and refer to it from code moved to a timeline frame?  And I think _global.mode set a variable "show_hotbox" available from anywhere within the main SWF...how should it be updated?
      on (rollOver) {
      if (Key.isDown(32)) {
        // 32 is the spcae bar key code
          flash.display.MovieClip.gotoAndStop("main");
      } else if (_global.mode = "show_hotbox") {
      Thank you very much, super appreciative!
