4 Replies Latest reply on Jun 16, 2009 12:53 AM by xandesign
    Need help with custom component reflecting tag change in design mode
    xandesign Level 1
      I'm relatively new to flex and I've been trying to build a simple actionscript component which draws a shape with a gradient fill. The actionscript code I've written draws a shape with a gradient using default settings, runtime and in design mode and when I change the width or height it is reflected both runtime and in design mode. The issue is that when I change the fill color of the gradient using the fillColor attribute in the MXML tag it is reflected runtime but not in design mode.
      If anyone can have a look at my code below and show me how to get the fillColor to be reflected in design mode I would be very grateful.
      Thanks in advance,
      Xander
      MXML Code
      <ns1:ColourBar id="testComp" width="100%" height="10" fillColor="[0x51cf51, 0x36cf36]" />
      ColourBar.as
      package components {
      import flash.display.GradientType;
      import mx.core.UIComponent;
      [IconFile("ColourBar.png")]
      public class ColourBar extends UIComponent {
      include "Version.as";
      public static const DEFAULT_MEASURED_WIDTH:Number = 100;
      public static const DEFAULT_MEASURED_MIN_WIDTH:Number = 1;
      public static const DEFAULT_MEASURED_HEIGHT:Number = 10;
      public static const DEFAULT_MEASURED_MIN_HEIGHT:Number = 1;
      private var _fillAlphas:Array = [100, 100];
      private var _fillColors:Array = [0x6289ba, 0x3670ba];
      private static const _ratios:Array = [0, 255];
      public function ColourBar() {
      super();
      override protected function commitProperties():void {
      super.commitProperties();
      override protected function measure():void {
      super.measure();
      measuredMinWidth = DEFAULT_MEASURED_MIN_WIDTH;
      measuredMinHeight = DEFAULT_MEASURED_MIN_HEIGHT;
              measuredWidth = DEFAULT_MEASURED_WIDTH;
              measuredHeight = DEFAULT_MEASURED_HEIGHT;
      override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void {
      super.updateDisplayList(unscaledWidth, unscaledHeight);
      graphics.beginGradientFill(GradientType.LINEAR, _fillColors, _fillAlphas, _ratios);
      graphics.drawRect(0, 0, unscaledWidth, unscaledHeight);
      public function set fillAlphas(value:Array):void {
      _fillAlphas = value;
      invalidateProperties();
      public function get fillAlphas():Array {
      return _fillAlphas;
      public function set fillColors(value:Array):void {
      _fillColors = value;
      public function get fillColors():Array {
      return _fillColors;
