11 Replies Latest reply on May 18, 2009 5:49 AM by eboda_snaf
    How to: Text Thread
    eboda_snaf Level 1
      How to write Javascript
      1. to Change the Text Thread color?
      2. to Show the text thread?
      Thanks a million!
        • 1. Re: How to: Text Thread
          AdobeScripts Level 3
          what do you mean - color of Text, color of background of TextFrames, color of TextFrames edges, etc. ?
          and again - show what ? lines between TextFrames showing TextFrames links ? or something else ?
          robin
          www.adobescripts.co.uk
          • 2. Re: How to: Text Thread
            eboda_snaf Level 1
            to change the thread color, mine text thread is light gray in color.
            Can change this color using JS?
            Thanks alot.
            • 3. Re: How to: Text Thread
              eboda_snaf Level 1
              and also using JS to Show the text thread..
              • 4. Re: How to: Text Thread
                Dave Saunders Level 4
                A text thread doesn't have a color, per se. It inherits the color from the UI color of the layer holding the text frames. Specifically, the thread connector is shown using the color of the "before" text frame.
                So, to change the color, you can either change the UI color of the layer holding the text frames or change the itemLayer of the frames.
                As to your second question, I don't think the show text threads option is exposed to scripting.
                Dave
                • 5. Re: How to: Text Thread
                  I searched in vain for text threads, first in ViewPreferences (the logical place), then with an exhaustive search all through the help. It's not there.
                  A strange omission, although not one that has been reported AWOL straightaway, so perhaps it's not that crucial to anyone else. Perhaps Ole knows why, if there is reason.
                  • 6. Re: How to: Text Thread
                    eboda_snaf Level 1
                    pardon me.. who's Ole?
                    Is he/she from Adobe?
                    • 7. Re: How to: Text Thread
                      hi
                      Ole is "he" and is from Adobe
                      you can find him somewhere here on forum
                      robin
                      • 8. Re: How to: Text Thread
                        Harbs. Level 6
                        To further enlighten you: Ole's full name is Olav Martin Kvern. He's the one who started this (scripting) forum and he "wrote the book" on InDesign and scripting (many of them...)
                        Harbs
                        • 9. Re: How to: Text Thread
                          eboda_snaf Level 1
                          Oh.. so I know another Indesign expert here in this forum.
                          anyway..
                          I would like to thank you people who have offered help and advice to an Indesign novice like me.
                          Many Thanks to You!!
                          • 10. Re: How to: Text Thread
                            WölfNorgren
                            you can use:
                            app.menuActions.item("$ID/Show Text Threads").invoke();
                            to show the linkages between text boxes (it is the same as selecting the menu 'View:Show Text Threads")
                            app.menuActions.item("$ID/Hide Text Threads").invoke();
                            will hide them.
                            I did a quick test, and there's something funky going on behind the scenes if you manually turn threads on and off through the menus, but this code seems to be reliable regardless of initial setting.
                            var showThreads = app.menuActions.item("$ID/Show Text Threads");
                            try {showThreads.invoke()} catch (givenError){};
                            var hideThreads = app.menuActions.item("$ID/Hide Text Threads");
                            try {hideThreads.invoke()} catch (givenError){};
                            Note that this actually leaves threads "ON", but that's why it's 'funky'. (Or I'm just not getting what's actually going on...)
                            Wölf
                            • 11. Re: How to: Text Thread
                              eboda_snaf Level 1
                              ya.. it works somehow. I also don't really understand
                              Thanks alot!
