0 Replies Latest reply on Sep 22, 2008 4:25 AM by COKFlex
    How to determine the text height in ADG?
    COKFlex
      Hi All,
      I am using AdvancedDataGrid to display which has variablerowHeight is set to True. Now all I wanted to know is that to detect the height of the text displayed in each row or height of each row.
      Because I am having horizontal grid lines after each row of text. Here the issue is, the space between the text an line drawn is not same at top and bottom. If I adjust that using "paddingTop" and "paddingBottom" set to 0 or some value, then if I change the fontname for the text, based on the fontname I use the space is either increased or decreased.
      The space between the text and line is same when single row records like below
      1) Using Font Comic Sans MS
      val1 val2 val3
      2) Using Font Arial
      val1 val2 val3
      But when I have the row values something like this, the issue is coming
      val1 val2 val3
      val4
      2) Using Font Arial
      val1 val2 val3
      val4
      Here in the second example, the space between the text and the line at the bottom is not same as the top.
      I hope I made my problem clear.
      Any help or suggestion would be helpful
