8 Replies Latest reply on May 16, 2009 11:24 AM by kergadic35
    databinding refresh problem
    kergadic35 Level 1
      I am a Flex Beginner and I have a problem with data binding. I have this small program :
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
              <![CDATA[
                  [Bindable] public var valeur:String;
          </mx:Script>
          <mx:ViewStack id="mainViewStack"  width="100%" height="100%">
              <mx:Panel id="panel1">
                      <mx:TextInput id="text1"/>
                      <mx:Button label="A" click="valeur='test';mainViewStack.selectedIndex=1;"/>
              </mx:Panel>
              <mx:Panel id="panel2">
                  <mx:TextInput id="text2" text="{valeur}"/>
                  <mx:Button label="B" click="mainViewStack.selectedIndex=0;"/>
              </mx:Panel>
          </mx:ViewStack>
      </mx:Application>
      - I switch between 2 panels ('A' button).
      - When I switch from panel1 to panel2 (click event), I change 'valeur' variable to 'test' (with databinding, text2 is updated).
      - After that, I modify manually the text2 valeur (for example "valeur123").
      - I switch from panel2 to panel1 ('B' button)
      - I switch one more time from panel1 to panel2 ('A' button)
      => and this time, the 'text2' TextInput is not updated ; the value does not change (still 'valeur123').
      So why the databinding does not work in that case ?
      Thank you for your help.
      Regards
      Greg
        • 1. Re: databinding refresh problem
          ATIF FAROOQ
          hi,
             you are trying to do 2-way data binding which is not yet implemented in flex 3 sdk you will need to wait for flex 4 to do that.
          • 2. Re: databinding refresh problem
            Michael Borbor Level 4
            probably because when you change manually the text you are overriding
            the binding.
            Sincerely,
            Michael
            El 16/05/2009, a las 11:32, kergadic35 <forums@adobe.com> escribió:
            layout="absolute">
                <mx:Script>
                    <![CDATA[
                </mx:Script>
                    </mx:Panel>
                        <mx:TextInput id="text2" text=""/>
                    </mx:Panel>
                </mx:ViewStack>
            </mx:Application>
            "valeur123").
            Regards
            Greg
            • 3. Re: databinding refresh problem
              kergadic35 Level 1
              Are you sure ?
              It seems to me that there is only a 1-way databinding, isn't it ?
              • 4. Re: databinding refresh problem
                Yes that's right in The next version of the flex sdk there's two way
                binding, but as Spiderman's grand pa said with great power comes great
                responsability.
                Sincerely,
                Michael
                El 16/05/2009, a las 12:19, kergadic35 <forums@adobe.com> escribió:
                Are you sure ?
                • 5. Re: databinding refresh problem
                  kergadic35 Level 1
                  Excuse me I was not clear.
                  I wanted to say that it seems to me that there is only a one-way binding in my program
                  Where do you see a 2-way binding in my code ?
                  • 6. Re: databinding refresh problem
                    Actually the Flex Sdk 3.* doesn't support two way binding so even if
                    you want to you can develop a two way binding app.
                    I didn't say your app implemented two way binding.
                    Sincerely,
                    Michael
                    • 7. Re: databinding refresh problem
                      ATIF FAROOQ Level 3
                      yes you were not trying to bind your data in 2 way but i said that because suppose if you have two way data binding support right now then you will not be facing that problem.consider the following two lines which suppose to execute two way data binding
                        <mx:Binding source="valeur" destination="text2.text"/>
                        <mx:Binding destination="valeur" source="text2.text"/>
                      try running the following application and see what happens
                          <mx:Script>
                              <![CDATA[
                          </mx:Script>
                          <mx:ViewStack id="mainViewStack"  width="100%" height="359" creationPolicy="all">
                              </mx:Panel>
                                  <mx:TextInput id="text2"/>
                              </mx:Panel>
                          </mx:ViewStack>
                          <mx:Label x="55" y="393"  width="198" height="40"/>
                      </mx:Application>
                      • 8. Re: databinding refresh problem
                        kergadic35 Level 1
                        Nice ! It works
                        Thank you very much for your help !
                        Regards
                        Greg
