3 Replies Latest reply on May 29, 2009 8:33 PM by hsg147
    Anyone succeeded installing Adobe Air on Fedora 10?
    hsg147
      I just tried to install AdobeAir on my Fedora 10 GNOME system but got an error message:
            Adobe AIR could not be installed. Either gnome-keyring or Kwallet must be installed prior
            to installing Adobe AIR.
      But gnome-keyring is installed on my system:
         [root@localhost Desktop]# yum list *ring*
         Loaded plugins: refresh-packagekit
         Installed Packages
         gnome-keyring.x86_64                          2.24.1-1.fc10                installed
         gnome-keyring-pam.x86_64                  2.24.1-1.fc10                installed
         gnome-python2-gnomekeyring.x86_64  2.23.0-1.fc10                installed
      so I don't know what to do next. I also can't find a Kwallet to install via yum (and am not sure that would work anyhow since I am not using the KDE desktop).
      Has anyone succeeded installing Air on Fedora 10? If so, can you email me how?
         Henry
        • 1. Re: Anyone succeeded installing Adobe Air on Fedora 10?
          hsg147 Level 1
          A partial solution to my own post: AdobeAir evidently is a 32-bit product and the specific error message was caused by my having a 64-bit system. When I used yum to install the 32-bit version of gnome-keyring , the AdobeAirInstaller.exe got further but then gave a new error message:
              "An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator."
          I ran the command as a superuser so I am confused why the Installer won't go the whole way, it should be able to install all necessary files. So I am still stuck, but in a new spot.
          • 2. Re: Anyone succeeded installing Adobe Air on Fedora 10?
            syed mehadi Level 2
            try adobe air installation on your Fedora 10 after installing xterm on it.
            sudo yum install xterm
            see if that resolves your issue.
            As 64-bit linux isn't supported officially, so please share the steps you did before installing 32-bit adobe air runtime on 64-bit fedora 10.
            • 3. Re: Anyone succeeded installing Adobe Air on Fedora 10?
              hsg147 Level 1
              syed mehadi <forums@adobe.com> writes:
              Please try adobe air installation on your Fedora 10 after
              installing xterm on it.  sudo yum install xterm see if
              This does not make a difference.
              I did find this webpage:
                  http://kb2.adobe.com/cps/408/kb408084.html
              which gives some suggestions about how to install Air on a
              64-bit Linux distribution, but the information is out of
              date, e.g., although Air evidently installs and works on a
              64-bit Fedora 8 system, it does not on Fedora 10. The
              recommended 32-bit libraries also don't exist (at least,
              they are not accessible via yum).
                  Henry
