3 Replies Latest reply on May 17, 2009 5:22 AM by Dan Bracuk
    how to add dynamic jquery fields into DB
    davella
      I am using the script from: http://www.coldfusionjedi.com/index.cfm/2009/2/19/Using-jQuery-to-add-form-fields to dynamically add fields to a form.  I am having trouble actually inserting the fields into a DB.  It seems that the field name is the same each time so they just get combined into one variable.  For instance, if field 1 is "John" and they add another person and his name is "Frank" field1 becomes, "John, Frank".
      I have a few more fields then that, so I am unsure how to proceed.  Anyone have any ideas or code samples that have worked for them?  Essentially I am trying to loop through the form and insert each additional field seperately.
      Any ideas?
      Thanks a ton
        • 1. Re: how to add dynamic jquery fields into DB
          Dan Bracuk Level 5
          Nested loops.  Outer loop is your formfields.  Inner loop is each field (treat them as lists).
          • 2. Re: how to add dynamic jquery fields into DB
            davella Level 1
            Thanks for the help!  I am still stuck as to exactly how this will be done. My form is as follows:
            Type:
            Price:
            Unite:
            Name:
            and users can add another product etc so there will be more fields for each additional product (which all seem to get truncated as a comma seperated list in the form value)
            Here is what I have so far, after the form is submitted:
            <cfloop item="key" collection="#form#">
            <cfquery name="insertnote">
            INSERT INTO Deals (type, price, unit, name) VALUES ('#form.type#', #form.price#, '#form.unit#', '#form.name#'  )
              </cfquery>
            </cfloop>
            I honestly don't use loops like this very often so I apologize for having a lack of understanding.  I know you mentioned making them nested loops but I dont' know how to do it and have it successfully insert the appropriate data.  Everytime I try it doesnt come out right.
            • 3. Re: how to add dynamic jquery fields into DB
              Dan Bracuk Level 5
              Hopefully, each time the user adds a product, something is appended to the end of every form field.  It becomes very easy.  In fact you don't even need nested loops.
              <cfloop from = "1" to = listlen(form.name) index = "i">
              INSERT INTO Deals
              VALUES
              ('#listgetat(form.type, i)#', #listgetat(form.price, i)#, '#listgetat(form.unit, i)#', '#listgetat(form.name, i)#'  )
              </cfquery>
              Also, cfqueryparam for a number of reasons.
