1 Reply Latest reply on May 19, 2009 5:23 AM by Hodmi
    Linked Fields
    GuidantJohn
      OK, I am new at this.  I have a small real estate company with 5 agents.  Ideally, I would like to have an intro screen asking for key data specific to a form and then have it populate throughout the form.  For example, an agent's contact information so it drops in all the key spots and they can just hit the print button.  This way they wouldn't have to type every field nor would I have to create a version specific to every agent.   Also, for client transactions, it would drop their names in the key form locations that I designate without having to re-type every location.  Is there a way to do this, or as a fallback, to have other form locations simply reflect the data in the first linked one?
        • 1. Re: Linked Fields
          Hodmi Level 4
          If you have a data connection (such as a schema or sample XML data) you can try binding all of the like fields to a single data node.  Otherwize you can try naming all of the like fields the same and setting the binding to Global.
