5 Replies Latest reply on Sep 22, 2008 7:24 AM by jon@cmiwebstudio
    clear text... why so difficult?
    jon@cmiwebstudio Level 3
      high end export... check
      anti-alias... check
      normal text like arial... check
      looks like garbage... check
      what's the deal?
      If I'm saving a graphic with Arial text, system or smooth anti-alias, and exporting is as a png 32, the highest setting possible... why should it still look terrible? For example, look at this rollover image here. some may thing that looks ok, but it's really not up to my standards.
      any advice on this? and I would rather not double the size and squeeze it, which to me seems like a cheesy workaround that doesn't help that much. There has to be a way to get truly crystal clear sharp looking text with no jaggies, glows, rings, smudges, or a look as if a gaussian blur filter was added to the image. does photoshop do any better then fireworks? I've created tons of great looking graphics for the web, yet text still seems like a constant chore.
        • 1. Re: clear text... why so difficult?
          Level 7
          > anti-alias... check
          > what's the deal?
          > http://204.9.76.17/images/nav_floating/surgery_over.png. some may thing that
          > image. does photoshop do any better then fireworks? Sorry... i'm frustrated.
          A common technique with the FW text engine is to put a duplicate right
          on top of the first text area. You will also get crisper text by using
          Crisp Anti-alias.
          I don't know what the rest of your design looks like, but you might want
          to consider html text and CSS for this type of rollover.
          HTH
          Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
          http://www.communityMX.com/
          CommunityMX - Free Resources:
          http://www.communitymx.com/free.cfm
          .:Adobe Community Expert for Fireworks:.
          http://tinyurl.com/2a7dyp
          See my work on Flickr
          http://www.flickr.com/photos/jim_babbage/
          • 2. Re: clear text... why so difficult?
            if you're working in illustrator, the text looks absolutely perfect. of course, when you export the image, you're in the same boat. is there any way to make text look like it does when you work in illustrator for the web?
            • 3. Re: clear text... why so difficult?
              Level 7
              You can try working at a higher resolution.
              Linda Rathgeber - Adobe Community Expert
              http://www.adobe.com/communities/experts/members/8.html
              • 4. Re: clear text... why so difficult?
                Level 7
                You could also try the CS4 Beta version of FWs, which is free to owners of
                legit CS3 version. The text is supposed to be better as CS4 uses the Adobe
                text engine now.
                Peter
                _______________
                "Linda Rathgeber" <lightly@sc.rr.com> wrote in message
                news:gb7q8j$goc$1@forums.macromedia.com...
                any way
                • 5. Re: clear text... why so difficult?
                  interesting, but I have to wonder how much clearer it can be.
                  i found using a copy of both layers, modifying the one to 50% opac seemed to sharpen things a bit. Still nothing like vector graphics.
