6 Replies Latest reply on May 18, 2009 4:20 AM by Patrisce
    Flex memory increases dramatically
    Patrisce
      Using a DataGrid and a simple Graph to display 50000 rows of xml data (e4x), causes Flex memory to increase dramatically.
      If you click and get the data several times (see attached sources ), you will eventually get the System memory to go over 1GB, which is way too much to handle for a standard browser/windows client (Internet Explorer 7, Flex 3.2, Flash Player 10).
      Note that in this example, I have tried to reproduce a problem that I have in a real world application. I always handle the data the same way:
      1. I get the data from HTTPservice as e4x
      2. I Load the data in a XMLListCollection source
      3. I assign the XMLListCollection source as a DataProvider to several graphs and datagrids.
      Please take a look at the source and let me know if I am doing anything wrong.
      Any help would be appreciated, as our customer is getting very impatient.
      -----------------------source--------------------------------------------------
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical"
           xmlns:local="*" width="100%" height="100%">
               <mx:Label id="totalMemory" styleName="linkBarMenu" text="{(System.totalMemory / 1024) + 'KB'}" render="totalMemory.text = (System.totalMemory / 1024) + 'KB'"/>
              <mx:Button label="get data" click="getData()"/>
               <mx:AdvancedDataGrid id="myDgd1" dataProvider="{rsltFilterXML}">
                  <mx:columns>
                      <mx:AdvancedDataGridColumn dataField="N"/>
                      <mx:AdvancedDataGridColumn dataField="NAME"/>
                      <mx:AdvancedDataGridColumn dataField="AGE"/>
                      <mx:AdvancedDataGridColumn dataField="HEIGHT"/>
                  </mx:columns>
               </mx:AdvancedDataGrid>
               <mx:AreaChart dataProvider="{rsltFilterXML}" width="100%" showDataTips="true">
                   <mx:series>
                  <mx:PlotSeries id="customeSerie" yField="AGE" xField="N"/>
                  </mx:series>
          </mx:AreaChart>
          <mx:HTTPService id="GetData" resultFormat="e4x" result="sasResults(event)" fault="handleFault(event)"
             method="POST" showBusyCursor="true"/>
      <mx:Script>
        <![CDATA[
                import mx.collections.XMLListCollection;
                import mx.controls.Alert;
                import mx.rpc.events.FaultEvent;
              import mx.rpc.events.ResultEvent;
              [Bindable] private var  rsltFilterXML:XMLListCollection = new XMLListCollection();
              private function getData():void
                  rsltFilterXML.source = null;
                  GetData.url="classroom.xml";
                   GetData.send();
                 public function handleFault(event:FaultEvent):void
                 Alert.show(event.fault.faultString, event.fault.message);
              private function sasResults(event:ResultEvent):void
                  rsltFilterXML.source = event.result.row;
        </mx:Script>
      </mx:Application>
        • 1. Re: Flex memory increases dramatically
          Patrisce Level 1
          Attaching data (classroom.xml)
          • 2. Re: Flex memory increases dramatically
            Srirangan
            You can consider using pagination by assigning a filter function on the dataProvider of the DataGrid.
            Or you might want to check out a lightweight DataGrid replacement: http://www.elfgrid.com/
            - Sri
            • 3. Re: Flex memory increases dramatically
              Michael Borbor Level 4
              Profile your app, to display the 50000 records Flex has to loop
              through each one, and using an XMLListCollection adds more overhead to
              this operation if the binding isn't important don't use
              XMLListCollection.
              Sincerely,
              Michael
              • 4. Re: Flex memory increases dramatically
                Patrisce Level 1
                Do you mean that even though I only display 10 rows, then flex will loop and assign memory to 50 000? I know it is a lot, but still the memory should not increase when assigning new data to the XMLListCollection. GC should eventually occur.
                • 5. Re: Flex memory increases dramatically
                  Patrisce Level 1
                  Now I have tried to remove the datagrid and the chart, and the Bindable, and use an ArrayCollection. The memory is still increasing. Is there a way to clean up the data before getting some new? I am guessing that Flex accumulates the data instead of cleaning up. Note that you only see this problem when you are dealing with a lot of data (size > 50000)
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" xmlns:elfgrid="http://www.elfgrid.com/2009"
                      <mx:HTTPService id="GetData" resultFormat="object" result="sasResults(event)" fault="handleFault(event)"
                  <mx:Script>
                    <![CDATA[
                        import mx.collections.ArrayCollection;
                          private var orgData:ArrayCollection;
                               GetData.send();
                              orgData = new ArrayCollection(event.result.row);
                    </mx:Script>
                  </mx:Application>
                  • 6. Re: Flex memory increases dramatically
                    I checked your code breifly, it's a nightmare review code in a cell
                    phone, that's where Profiling comes in handy, somehere there must be a
                    memory leak, or the ADG isn't doing something right.
                    In order to the GC to run all reference to an object must be remove,
                    in your case that wouldn't happen because you use the XML always, I
                    didn't see a filter in your app to show only 10 records, probably I
                    missed it.
                    Sincerely,
                    Michael
