1 Reply Latest reply on May 18, 2009 6:35 AM by BennyBeta
    what is wrong  with my menu hierachies?
    axelbp
      hi,
      i have a problem with menu hierachies.
      after debugging my program i took the example of the Menu Component(SimpleMenuExample.mxml)
      from the Actionscript Component Documentation.
      i only changed the xml menu definition to 3 levels,and also then the second menu hierachy is not shown:
      <mx:XML id="myMenuData">
      <root>
        <menuitem label="MenuItem 1">
           <menuitem label="MenuItem 11" >
             <menuitem label="MenuItem 111"/>
           </menuitem>
         </menuitem>
      </root>
      </mx:XML>
      with  :
      myMenu= Menu.createMenu(panel, myMenuData, false);
      myMenu.labelField="@label";
      so the problem is: the menu "MenuItem11" doesnt appear !
      so where is something wrong?xml definition?
      thanks axel
        • 1. Re: what is wrong  with my menu hierachies?
          BennyBeta Level 4
          I'm not sure why "Menu Item 11" is not showing, but you can make it show by adding another item ("Menu Item 1A") at the same level.
                  <root>
                       <menuitem label="MenuItem 1A" />
                       </menuitem>
                     </menuitem>
                  </root>
          I hope that helps solve your problem.
          Ben Edwards
