0 Replies Latest reply on May 18, 2009 6:30 AM by myg-mimi
    not precise vector copy&paste from Illus cs4 to flash cs4
    myg-mimi
      does somebody knows if there is a solution to that or does somebody have an explanation to this ...
      I have a really complex shape made in Illustrator cs4 that I need to import in flash cs4. When I import my shape in flash , my shape doesn't keep the exactly, precisely same shape. I try to reduce the amount of point with illustrator with Object->path->simplify ... It's help but not enough. My shape is to complex to re-draw one by one every single points as the original.
      I did some test as in Flash cs3 and this problem dosen't exist. In cs4 you can test it do a circle , the smallest you can and zoom , you will see that the circle is not a circle anymore. (cs3 does't do it)
      Help
