1 Reply Latest reply on May 19, 2009 4:10 AM by René Mølsted
    InDesign Server as Mac OS Daemon
    jamiedellemonache Level 1
      I'm trying to configure a Launchd plist for an IDS instance. I can get the process running just fine as user agent, but I want it to run unattended. the problem so far, as I can determine, is where IDS puts configuration preferences:
      /users/[user_name]/Library/Preferences/Adobe InDesign Server/Version 5.0/[configuraion_name]
      When launched from Root at startup it never seems to see the configuration perf. I've even tried launching IDS from within the Pref folder. Unfortunately Adobe's documentation is a little thin on this topic.
      Any help is greatly appreciated
      j.
      the current plist I'm working with looks like this:
      <?xml version="1.0" encoding="UTF-8"?>
      <!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
      <plist version="1.0">
      <dict>
      <key>Disabled</key>
      <true/>
      <key>Label</key>
      <string>com.adobe.ids.pagepics</string>
      <key>OnDemand</key>
      <false/>
      <key>ProgramArguments</key>
      <array>
      <string>/Applications/Adobe_InDesign_CS4_Server/InDesignServer</string>
      <string>-configuration</string>
      <string>k4pagepics</string>
      <string>-previews</string>
      <string>-k4consolelog_actions</string>
      <string>-k4makepagepics</string>
      <string>-LogToApplicationEventLog</string>
      </array>
      <key>RunAtLoad</key>
      <true/>
      </dict>
      </plist>
        • 1. Re: InDesign Server as Mac OS Daemon
          René Mølsted
          Hi Jamie
          I'm using this on 10.5 with IDS CS4:
          <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
          <dict>
               <key>Label</key>
               <string>com.molsted.InDesignServer</string>
               <array>
                    <string>/Applications/Adobe InDesign CS4 Server/InDesignServer.app/Contents/MacOS/InDesignServer</string>
                    <string>-port</string>
                    <string>18384</string>
               </array>
               <true/>
          </dict>
          </plist>
          Put the file in either /Library/LaunchAgents/com.molsted.InDesignServer.plist or ~/Library/LaunchAgents/com.molsted.InDesignServer.plist
          launchctl load -w /Library/LaunchAgents/com.molsted.InDesignServer.plist
          or
          launchctl load -w ~/Library/LaunchAgents/com.molsted.InDesignServer.plist
          to stop the daemon, issue this command:
          launchctl unload -w /Library/LaunchAgents/com.molsted.InDesignServer.plist
          or
          launchctl ubload -w ~/Library/LaunchAgents/com.molsted.InDesignServer.plist
          René Mølsted
