5 Replies Latest reply on Jul 31, 2009 1:32 PM by Kasyan Servetsky
    Indesign autosave
    eboda_snaf Level 1
      I believe there's some autosaving and backup feature in Indesign, where to turn off this option or rather set to a longer time..
      My Indesign will get slow at some time interval.
      Heeeeellllp..
        • 1. Re: Indesign autosave
          Peter Kahrel Adobe Community Professional & MVP
          You can't disable InDesign's autosave or its building up an undo cache. What you can do is save documents using the equivalent of "Save As" in the UI, which deletes the document's undo cache:
          myDoc.save (File (myDoc.fullName));
          Peter
          • 2. Re: Indesign autosave
            Harbs. Level 6
            It's not really an auto-save. You're talking about the undo stack. The
            functionality is integral to InDesign, and you can't turn it off. You
            can clear the undo stack every once in a while by doing a save as to
            get performance to pick up.
            Harbs
            http://www.in-tools.com
            • 3. Re: Indesign autosave
              Harbs. Level 6
              Peter,
              Sorry about repeating your responses.
              I have to stop responding to questions while commuting. By the time I reconnect to the internet, I keep finding that someone else answered before me...
              Harbs
              • 4. Re: Indesign autosave
                Jansseune Level 1
                It seems to me that Adobe have got the autosave featured sorted out, but what concerns me is what happens when a disk goes down and you lose the original and the autosave (Recovered) file on the same disk? This one thing Quark seems to have over Indesign in that you can specify where you want your backup to be i.e.on another disk entirely. Is this possible in ID?
                • 5. Re: Indesign autosave
                  Kasyan Servetsky Level 5
                  Go to Preferences > File Handling > Document Recovery Data choose Browse and select another folder on another disk.
                  P.S. I'm not sure if you will be able to restore these data, in case your disk goes down together with installed copy of InDesign.
