11 Replies Latest reply on May 18, 2009 1:06 PM by rcanulla
    Controlling properties on items added to the stage in a loop
    rcanulla Level 1
      Hi there,
      I have a loop that adds xml elements to the stage (10). Once added, I need to control the items (checkbox = do something).
      Here is where I add them to the stage.
                private function createLayout():void {
                     container = new VBox();
                     for(var i:int=0; i<10; i++) {
                          vBox = new VBox();
                          hBox = new HBox();
                          titleText = new LinkButton();
                          itemInfo = new Text();
                          abstract = new Text();
                          archive = new CheckBox();
                          rateItem = new ComboBox();
                          category = new ComboBox();
                          var categoryLabels:Array = new Array("Food & Ag","News","Health","People","General","What's Coming","Biofuel","Environment");
                          var rateLabels:Array = new Array("Excellent","Good","Bad","Neutral","Controversial");
                          titleText.label = listCollection.getItemAt(i).title;
                          titleText.width = 400;
                          itemInfo.text = listCollection.getItemAt(i).source + " | " + listCollection.getItemAt(i).date;
                          abstract.text = listCollection.getItemAt(i).abstract;
                          abstract.width = 400;
                          archive.label = "Archive";
                          category.prompt = "Category";
                          category.dataProvider = categoryLabels;
                          category.rowCount = categoryLabels.length;
                          rateItem.prompt = "Rate";
                          rateItem.dataProvider = rateLabels;
                          vBox.addChild(titleText);
                          vBox.addChild(itemInfo);
                          vBox.addChild(abstract);
                          vBox.addChild(hBox);
                          hBox.addChild(archive);
                          hBox.percentWidth = 80;
                          hBox.percentHeight = 80;
                          archive.addEventListener(Event.CHANGE, toggleArchive);
                          container.addChild(vBox);
                     addChild(container);
      I listen for a checkbox (change event) and when clicked, call a function that adds two comboboxes to the stage.
      I then call the function that will handle the event.
                public function toggleArchive(e:Event):void {
                     if(archive.selected == true){
                          hBox.addChild(category);
                          hBox.addChild(rateItem);
                     else {
                          hBox.removeChild(category);
                          hBox.removeChild(rateItem);
      When I have one item it works fine.
      for(var i:int=0; i<1; i++) {
      When I add 10 nothing happens. I feel like i should be doing something to identify what item I'm referring to. Any thoughts/reccomendations would br great!
        • 1. Re: Controlling properties on items added to the stage in a loop
          Gregory Lafrance Level 6
          Give your category and rateItem objects names, like category.name = "category";
          then don't add remove based on ComboBox, but set these properties:
          var cb:ComboBox = myTopVBox.getChildAt(i).getChildByName(category);
          cb.visible = false;
          cb.includeInLayout = false;
          • 2. Re: Controlling properties on items added to the stage in a loop
            rcanulla Level 1
            My apologies, but I am somewhat confused. Thanks for taking the time to help me (first off)!
            I changed the createLayout function to add name, visible, and includeInLayout propertiesfor each comboBox. I then changes the scope of "i" so that I can reference it from the function called upon the Event.CHANGE event.
                      private var i:Number;
                           for(var i=0; i<listCollection.length; i++) {
                                vBox = new VBox();
                                hBox = new HBox();
                                category.visible = false;
                                category.includeInLayout = false;
                                rateItem.name = "rateItem";
                                rateItem.visible = false;
                                rateItem.includeInLayout = false;
            now I have to modify these items by name from the toggleArchive method.
                                var cb:ComboBox = hBox.getChildAt(i).getChildByName(category);
                                cb.visible = true;
                                cb.includeInLayout = true;
                           else {
            Two things, 1) i get an error saying...
            Severity and Description    Path    Resource    Location    Creation Time    Id
            1061: Call to a possibly undefined method getChildByName through a reference with static type flash.display:DisplayObject.    mediaTrap/src/components    listItems.mxml    line 132    1242667335601    643
            2) shouldnt it be something like this
                           if(hBox.getChildAt(i).archive.selected == true){
                                cb.visible = true;
                           else {
            • 3. Re: Controlling properties on items added to the stage in a loop
              Yeah. I was generalizing, but seems you figured it out in your app.
              • 4. Re: Controlling properties on items added to the stage in a loop
                rcanulla Level 1
                do you have any thoughs regarding the error? I actually have no idea about this. Sorry!
                error
                1119: Access of possibly undefined property selected through a reference with static type flash.display:DisplayObject.    mediaTrap/src/components    listItems.mxml    line 133    1242669734737    661
                1119: Access of possibly undefined property includeInLayout through a reference with static type flash.display:DisplayObject.    mediaTrap/src/components    listItems.mxml    line 135    1242669873712    665
                Why do you use getChildAt & getChildByName? Why can't I just do something like this?
                               if(archive.getChildAt(i).selected == true){
                                    rateItem.getChildAt(i).visible = true;
                                    rateItem.getChildAt(i).includeInLayout = true;
                               else {
                • 5. Re: Controlling properties on items added to the stage in a loop
                  ComboBox(archive).getChildAt(i).selected == true
                  • 6. Re: Controlling properties on items added to the stage in a loop
                    rcanulla Level 1
                    Can you please be more descriptive? I have no idea what that means.
                    I'm sorry because I feel annoying. Let me know if I am, and I'll stop bugging you.
                    • 7. Re: Controlling properties on items added to the stage in a loop
                      You're not annoying, just curious.
                      It looks like Flex in this case is treating archive as a generic DisplayObject, so you need to cast it back to its real datatype (ComboBox).
                      So:
                          if(((ComboBox)archive.getChildAt(i)).selected == true){
                      • 8. Re: Controlling properties on items added to the stage in a loop
                        rcanulla Level 1
                        Phew. I am curious, very curious.
                        I did as stated before, and understand the need for casting the object so that flash knows how to handle it, but am getting differint errors now.
                                  //     else {
                                  //          trace("test");
                        getting these errors. all on the line below.
                        error.
                        1008: Attribute is invalid.    mediaTrap/src/components    listItems.mxml    line 133    1242672962051    701
                        1084: Syntax error: expecting identifier before dot.    mediaTrap/src/components    listItems.mxml    line 133    1242672962050    700
                        1084: Syntax error: expecting rightparen before archive.    mediaTrap/src/components    listItems.mxml    line 133    1242672962050    699
                        • 9. Re: Controlling properties on items added to the stage in a loop
                          You misplaced your parenthesis:
                          • 10. Re: Controlling properties on items added to the stage in a loop
                            rcanulla Level 1
                            i feel like I'm getting it! Still not working, but I think I'm understanding...
                            So the issue is that flash doesn't see the CheckBox() archive as a CheckBox and rateItem as a ComboBox. I'm still getting errors that flash doesn't recognize the property includeInLayout & selected. I DO NOT get and error for visible? Thoughts?
                            line 133-->         if((CheckBox(archive).getChildAt(i)).selected == true){
                                              (ComboBox(rateItem).getChildAt(i)).visible = true;
                            line 135-->             (ComboBox(rateItem).getChildAt(i)).includeInLayout = true;
                                           else {
                                                trace("test");
                            1119: Access of possibly undefined property includeInLayout through a reference with static type flash.display:DisplayObject.    mediaTrap/src/components    listItems.mxml    line 135    1242674897089    725
                            1119: Access of possibly undefined property selected through a reference with static type flash.display:DisplayObject.    mediaTrap/src/components    listItems.mxml    line 133    1242674897088    724
                            • 11. Re: Controlling properties on items added to the stage in a loop
                              rcanulla Level 1
                              also, I should note, it looks like i am getting the problem when using getChildAt() method. I can access the item fine when only instantiating once.
                              Should I listen for which one is clicked and pass that info?
