4 Replies Latest reply on May 18, 2009 10:10 AM by released87
    Referencing tilelist id
    released87 Level 1
      I am developing a shopping cart similar to the Flex Store Application Demo by Adobe. The products are rendered from XML using a TileList. I am able to display the products fine, and add them to the cart, which is basically just a new array. However, I am having some difficulty trying to reference the ID of the item in the array from the TileList.
      <mx:TileList
      dataProvider="{cartData}">
           <mx:itemRenderer>
                <mx:Component>
                     <mx:Box>
                          <mx:Label text="SKU#: {data.number}" />
                          <mx:Text text="Unit Cost: ${data.cost}" />
                          <mx:HBox>
                               <mx:Label text="Quantity" />
                               <mx:TextInput width="30" text="{data.quantity}" change="outerDocument.quantity()" />
                               <mx:Button label="Remove from cart" click="outerDocument.removeCart(ID OF CURRENT ARRAY ITEM);" />
                          </mx:HBox>
                     </mx:Box>
                </mx:Component>
           </mx:itemRenderer>
      </mx:TileList>
      public
      function removeCart(selectedID:int):void {
           cartData.removeItemAt(selectedID);
           updateCart();
      The problem I am having is I am unable to reference the current List item id in the tile list/cartData Array Collection. I have also tried adding an incremental id specific to the cartData Array Collection Item, so each time a new item is added the id is incremented. However, I am unable to find the particular array item containing the id.
      What is the best way to remove the array item using a button within the tile list component?
        • 1. Re: Referencing tilelist id
          Gregory Lafrance Level 6
          If you use a custom event, so you can pass the TileList selectedIndex:
          <mx:TileList id="myTL" dataProvider="{cartData}">
              <mx:itemRenderer>
                  <mx:Component>
                      <mx:Box>
                          <mx:HBox>
                              <mx:Button label="Remove from cart" click="outerDocument.removeCart(myTL.selectedIndex);" />
                          </mx:HBox>
                      </mx:Box>
                  </mx:Component>
              </mx:itemRenderer>
          </mx:TileList>
          public function removeCart(selectedIndex:int):void {
              cartData.removeItemAt(selectedIndex);
              updateCart();
          • 2. Re: Referencing tilelist id
            released87 Level 1
            thanks, i actually used
            outerDocument.list_cart.selectedIndex
            I think I need to use outerDocument.
            Another question I have is this...
            <mx:TextInput
            width="30" id="input_quantity" text="{data.quantity}" change="outerDocument.quantity(outerDocument.list_cart.selectedIndex, outerDocument.list_cart.selectedItem.quantity as int)"
            I want to change the quantity when a user types the quantity in the text input.
            public
            function quantity(selectedID:int, quantity:int):void {
            Alert.show(selectedID+
            " "+quantity);
            var cartObject:Object= new Object();
            cartObject.name= cartData[selectedID].name;
            cartObject.number= cartData[selectedID].number;
            cartObject.cost= cartData[selectedID].cost;
            cartObject.quantity= quantity;
            cartData.setItemAt(cartObject, selectedID);
            updateCart();
            I am not sure how to reference the textInput. I tried outerDocument.list_cart.selectedItem.input_quantity.text so the value gets passed to the function that will change the value in the array collection. However, that did not work so i tried the data.quantity binding, however, because it is bindable i am unable to actually change the amount. Do you know how I can change the quantity?
            • 3. Re: Referencing tilelist id
              Give the TextInput a value for the name property, then access it this way:
              click="setQuantity(myBtn.parent.getChildByName(myTI));"
              If this post helped, please mark it as such.
              • 4. Re: Referencing tilelist id
                released87 Level 1
                greg thank you much your help is mucho appreciated:)
