1 Reply Latest reply on May 19, 2009 5:59 PM by Moenizzle
    Progress bar lags when image is being loaded
    Moenizzle Level 1
      I am trying to load a series of images and display them in a TileList as thumbnails.  The problem is that, depending on how many images are loaded at once, there is a long delay.  I'm okay with the delay as long as I can display some sort of indeterminate progress bar.  Unfortunately, the application sort of hangs as the images are loading and the progress bar freezes/lags.  I'm wondering if there is a way to remedy this.
      Here are the steps I go through to load an image:
      1. Load an image into a ByteArray using fileReference.load()
      2. Load those bytes into a Loader using loader.loadBytes(..)
      3. Retrieve the content Bitmap from the Loader and scale it using bitmapData.copyPixels(..)
      Below is some code that is basically in sequence:
      // Load the image from a file
      public function load():Boolean
           if(_fileReference != null)
                _fileReference.addEventListener(Event.COMPLETE, onFileLoadComplete);
                _fileReference.load();
                return true;
           return false;
      // Fired after the FILE is loaded
      public function onFileLoadComplete(event:Event):void
           var currFileReference:FileReference = FileReference(event.target);
           currFileReference.removeEventListener(Event.COMPLETE, onFileLoadComplete);
           loadImage(currFileReference.data);
      // Begins loading the IMAGE into memory
      public function loadImage(imageByteArray:ByteArray):void
           var loader:Loader = new Loader();
           loader.contentLoaderInfo.addEventListener(Event.COMPLETE, onImageLoadComplete);
           loader.loadBytes(imageByteArray);
      // Fired after the IMAGE is loaded
      public function onImageLoadComplete(event:Event):void
           var loaderInfo:LoaderInfo = LoaderInfo(event.target);
           loaderInfo.removeEventListener(Event.COMPLETE, onImageLoadComplete);
           // Set ORIGINAL size image
           this.originalImage = loaderInfo.loader.content as Bitmap;
           this.originalImage.smoothing = true;
           // Set SCALED size image
           var minDimension:Number = this.originalImage.width > this.originalImage.height ? this.originalImage.height : this.originalImage.width;
           var x:Number = Math.max(0, (this.originalImage.width / 2) - (minDimension / 2));
           var y:Number = Math.max(0, (this.originalImage.height / 2) - (minDimension / 2));
           this.scaledImage = cropBitmap(this.originalImage, x, y, minDimension, minDimension);
           this.scaledImage.smoothing = true;
      public
           var croppedBitmapData:BitmapData = new BitmapData(w, h);
           croppedBitmapData.copyPixels(sourceBitmap.bitmapData,
      function cropBitmap(sourceBitmap:Bitmap, x:Number, y:Number, w:Number, h:Number):Bitmap
      new Rectangle(x, y, w, h), new Point(0, 0));
           return new Bitmap(croppedBitmapData);
      Any help would be GREATLY appreciated!
      Thanks!
      Moshe
