1 Reply Latest reply on May 19, 2009 10:25 AM by starfighter10
    login issue flex/php
    starfighter10
      Hello,
      I found a working loginscreen with usern,pass and button. I want to extend it with a login admin. When he is logged in, there are extra panels visible then when a user is logged in.
      I've tried different things, first I'll give you the one that works WITHOUT the admin..
      <?php
      define( "DATABASE_SERVER", "**" );
      define( "DATABASE_USERNAME", "***" );
      define( "DATABASE_PASSWORD", "**" );
      define( "DATABASE_NAME", "*" );
      //connect to the database
      $mysql = mysql_connect(DATABASE_SERVER, DATABASE_USERNAME, DATABASE_PASSWORD) or die(mysql_error());
      //select the database
      mysql_select_db( DATABASE_NAME );
      //asign the data passed from Flex to variables
      $username = mysql_real_escape_string($_POST["username"]);
      $password = mysql_real_escape_string($_POST["password"]);
      //Query the database to see if the given username/password combination is valid.
      $query = "SELECT * FROM users WHERE username = '$username' AND password = '$password'";
      $result = mysql_fetch_array(mysql_query($query));
      //start outputting the XML
      $output = "<loginsuccess>";
      if(!$result)
      $output .= "no";
      }else{
      $output .= "yes";
      $output .= "</loginsuccess>";
      //output all the XML
      print ($output);
      flex code:
      private function checklogin(evt:ResultEvent):void
      if(evt.result.loginsuccess == "yes")
      _user = this.username.text;
      this.lblwelkom.text="Welkom " + _user;
      currentState = ""
      if(evt.result.loginsuccess == "no")
      mx.controls.Alert.show("Invalid username/password");
      THEN THE CODE I'VE TRIED TO INCLUDE THE ADMIN==>
      With wampserver I connect to database with fields username,password and admin. When a personis admin he has the word 'admin' in the admin column, when he's just a user the field is left blank.
      So I tried different things, first with creating a second query in the php file: I’ve put the added code in color!
      <?php
      $query = "SELECT * FROM users WHERE username = '$username' AND password = '$password' AND admin is null";
      $query2 = "SELECT * FROM users WHERE username = '$username' AND password = '$password' AND admin is not null";
      $result2 = mysql_fetch_array(mysql_query($query2));
      if($result)
        $output .= "yes";
      if($result2)
        $output .= "admin";
      else
      $output .= "no";
      print ($output);
                                                     if(evt.result.loginsuccess == "admin")
        this.pnlmonbeheer.visible=true;
        currentState = "";
        currentState = "";
                                                     else(evt.result.loginsuccess == "no")
      I think I'm not using the right php code. Anyone?
      It would be really helpfull, thank thanks in advance
        • 1. Re: login issue flex/php
          starfighter10 Level 1
          Can anyone help me please?
          In short terms, I want to extend a working php script with an extra "admin" next to a "user". So there are two different sort of persons who can log in and so there will appear different panels. I think the working php, which I copied below, should have an extra query with an "admin is not null", so there will be another if statement with $output .= "admin";
          But somehow it doesn't seem to work, anyone?
          php code:
          if(!$result)
          $output .= "no";
          }else{
          $output .= "yes";
          print ($output);
          thanks in advance
