2 Replies Latest reply on May 18, 2009 4:08 PM by flaming1
    AddGuides applescript defaults
    flaming1 Level 2
      Hi
      I use this script a lot in my catalogue work, but I find myself in the main turning off most the options each time I use it. For example I rarely want to use the horizontal centre or vertical centre options. Is there a simple way to make the dialog open with the 'Top, left, bottom, right, horizontal centre, vertical centre' options turned off?
      I specifically want to use the Applescript version as I find that the Javascript version only works sometimes.
      Thanks in advance.
      Steve
        • 1. Re: AddGuides applescript defaults
          Olav Martin Kvern Level 3
          Hi Steve,
          You can edit the script. In the following section:
          tell (make dialog column)
          set myTopCheckbox to make checkbox control with properties {static label:"Top", checked state:true}
          set myLeftCheckbox to make checkbox control with properties {static label:"Left", checked state:true}
          set myBottomCheckbox to make checkbox control with properties {static label:"Bottom", checked state:true}
          set myRightCheckbox to make checkbox control with properties {static label:"Right", checked state:true}
          set myXCenterCheckbox to make checkbox control with properties {static label:"Horizontal Center", checked state:true}
          set myYCenterCheckbox to make checkbox control with properties {static label:"Vertical Center", checked state:true}
          set myXPointCheckbox to make checkbox control with properties {static label:"Path Point Horizontal Anchor", checked state:true}
          set myYPointCheckbox to make checkbox control with properties {static label:"Path Point Horizontal Anchor", checked state:true}
          end tell
          ...just set the checked state to false for the ones you don't want.
          Ole
          • 2. Re: AddGuides applescript defaults
            flaming1 Level 2
            Thanks for your help Ole.
            Much appreciated.
            Steve
