3 Replies Latest reply on May 19, 2009 7:14 AM by Michael Borbor
    Question on Custom Icon Function
    apmyhr
      I have a custom icon function for an AdvancedDataGrid which looks like this...
      Embed(source="assets/small_constellation.jpg")] public var
      ConstellationImg:Class;
      Embed(source="assets/small_satellite.jpg")] public var
      ResourceImg:Class;
      private function CustomIconFunction(item:Object):Class
      if (item is constellation) { return ConstellationImg; }
      else { return ResourceImg; }
      This has worked fine but I now want to change it so that my program loads the image from the server it runs on.  I tried using the following code:
           var constImage:Class = new Class();
           constImage.source = "imgUrl";
           return constImage;
      However, I get an error stating that Class() is not a constructor.  Any suggestions?
        • 1. Re: Question on Custom Icon Function
          Gregory Lafrance Level 6
          You can use a url from the server, but I don't think you can use the syntax you are using, with the constructor.
          Just use the syntax you were using but have a url for the image on the server.
          • 2. Re: Question on Custom Icon Function
            apmyhr Level 1
            I don't think that is exactly what I want to do.  If I understand what "Embed" means, I think the image is embeded into the swf file during compilation.  What I would like to do is load the image during run time.  There are a couple of reasons for this.  I don't want to hardcode server URL's into the compiled swf file.  Also, I would like to be able to change the actual images themselves without having to recompile the swf file every time.
            • 3. Re: Question on Custom Icon Function
              Michael Borbor Level 4
              If I'm not wrong buttons can only use Embeded images. Or images classes.
              Sincerely,
              Michael
