0 Replies Latest reply on May 19, 2009 8:52 AM by fmaas@incontext.nl
    Any chance to configure TURN proxy from application?
    fmaas@incontext.nl
      Have got a TURN proxy working as a remedy for the symmetric NAT issue.
      However, the way to configure this proxy in the mms.cfg file is rather inconvenient for two reasons:
      1. It works for all p2p applications running on the same Flash player instance, not just ours.
      2. The directory where mms.cfg is located is locked for many users.
      I understand that this way of configuring makes sense for the original use case (UDP blocked in organization's firewall), but for symmetric NAT case it is problematic.
      Question: is there a way we could specify the proxy URL from the application through some sort of undocumented API feature?
      - Frans
