0 Replies Latest reply on May 19, 2009 9:17 AM by Peter Farland
    [svn:fx-trunk] 7071: Providing assignable lvalue context while parsing rvalues in preparation to fix bugs such as SDK-17748 and SDK-18877 .
    Peter Farland Level 3
      Revision: 7071
      Author:   pfarland@adobe.com
      Date:     2009-05-19 08:17:09 -0700 (Tue, 19 May 2009)
      Log Message:
      Providing assignable lvalue context while parsing rvalues in preparation to fix bugs such as SDK-17748 and SDK-18877. This change makes the compiler aware of a new piece of metadata . When parsing text values, this metadata instructs the TextParser to not look for literal syntax for Arrays, Booleans, Numbers, etc... and instead just treat the content as String. However, it will still honor { } binding syntax and @function syntax.
      Once TLF and Gumbo text components are updated to use this metadata on the appropriate properties we will be able to close the bugs mentioned above.
      QE: Not yet
      Doc: No
      Checkintests: Pass
      Cyclone Tests: Mxunit, Mxunit - compc, Mxunit - rsl, Mxmlcunit, Compiler api all pass.
      Reviewer: Paul
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-17748
          http://bugs.adobe.com/jira/browse/SDK-18877
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ArrayBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/PrimitiveBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/VectorBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/NodeTypeResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/TextParser.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/ValueNodeHandler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Effect.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Property.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Style.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/StatesModel.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Assignable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/DynamicProperty.java
