13 Replies Latest reply on May 26, 2009 4:10 PM by fazstp
    degree symbol displays as infinity on Mac.
    kar13 Level 1
      I have a frustrating issue that I can't solve. Adobe won't help me because Director MX 2004 is "beyond it's product support life cycle."
      Hopefully someone here can help me out...
      ·         I’m using Director MX 2004.
      ·         I have scrolling text boxes that contain the degree symbol. I’m using the font Arial. Once I shock the file and view it on a Mac, in Safari or FF, the degree symbol displays as the infinity symbol instead. On the PC it looks like a degree symbol, as expected.
      ·         I’ve tried using the ASCII character (alt 0176) as well as the Symbol font character.
      ·         I’ve tried setting the “save bitmap” property of the text box to both true and false. Neither work.
      ·         This is only happening with text boxes. Text fields display the degree symbol just fine on Mac and PC. However, due to the very limited formatting capabilities of the text field, I am unable to just use text fields instead of text boxes.
      ·         How do I get special characters (degree symbol, bullet) to display correctly cross-platform in a text box??
      Thanks for any help.
      -Karen
        • 1. Re: degree symbol displays as infinity on Mac.
          Sean_Wilson Adobe Community Professional
          You could research which keyCode corresponds to the degree symbol on Mac and then use the beginSprite event in a behavior attached to your #text sprites to scan for chars with a particular keyCode and replace them with the correct one. You could even use a JavaScript regular expression if speed is an issue.
          • 2. Re: degree symbol displays as infinity on Mac.
            fazstp Level 2
            In a text field on my Mac with Arial font the degree symbol is numToChar( 188 )
            • 3. Re: degree symbol displays as infinity on Mac.
              kar13 Level 1
              Sean,
              Thanks for responding. How would that work exactly? Would it only replace the character on Mac OS systems? I'd have to include some code to determine the OS? I'm not a programmer, so any additional input on this sprite behavior would be great. Thanks.
              • 4. Re: degree symbol displays as infinity on Mac.
                kar13 Level 1
                fazstp,
                Thanks for the info. Hopefully I can use it in conjuction with Sean's idea.
                • 5. Re: degree symbol displays as infinity on Mac.
                  Chunick Level 3
                  The ASCII Character Set is only the same between PC and Mac up to 128: http://img.brothersoft.com/screenshots/softimage/a/ascii_table-84123-1.jpeg
                  Above 128 it's anyone's game... this is called the Extended Character Set: http://academic.evergreen.edu/projects/biophysics/technotes/program/ascii_ext-mac.htm
                  • 6. Re: degree symbol displays as infinity on Mac.
                    fazstp Level 2
                    on SetDegreeChar
                      win_char = numToChar( 176 )
                      mac_char = numToChar( 188 )
                      if ( the platform contains "Mac" ) then
                        SearchAndReplace( member( "my text field" ), win_char, mac_char )
                      else
                        SearchAndReplace( member( "my text field" ), mac_char, win_char )
                      end if
                    end SetDegreeChar
                    on SearchAndReplace text_member, search_string, replace_string
                      if NOT ( ilk( text_member ) = #member ) then
                        return FALSE
                      end if
                      if NOT ( text_member.type = #text ) then
                        return FALSE
                      end if
                      if NOT stringP( search_string ) AND ( search_string <> EMPTY ) then
                        return FALSE
                      end if
                      if NOT stringP( replace_string ) then
                        return FALSE
                      end if
                      start_char = 1
                      repeat while ( text_member.char[start_char..text_member.char.count] contains search_string )
                        char_num = offset( search_string, text_member.char[start_char..text_member.char.count] )
                        if NOT ( char_num ) then
                          exit repeat
                        end if
                        start_chunk = start_char + char_num - 1
                        end_chunk = start_chunk + search_string.char.count - 1
                        put replace_string into text_member.char[start_chunk..end_chunk]
                        start_char = start_chunk + replace_string.char.count
                      end repeat
                      return TRUE
                    end SearchAndReplace
                    • 7. Re: degree symbol displays as infinity on Mac.
                      kar13 Level 1
                      fazstp,
                      Oh my gosh! Thanks. I would have never been able to write that code! I can't wait to test it out when I get to work tomorrow!
                      • 8. Re: degree symbol displays as infinity on Mac.
                        Stephen already provided a code solution, but here's an alternative:
                        -- scriptText of a scriptSyntax = #lingo movieScript member:
                        on SetDegreeChar aMember
                          -- error check input
                          if ilk(aMember, #member) = 0 then return
                          if [#text, #field].getPos(aMember.type) = 0 then return
                          tText = aMember.text
                          if offset( the platform, "Mac" ) then
                            newText = jsReplace( tText, win_char, mac_char )
                          else
                            newText = jsReplace( tText, mac_char, win_char )
                          end if
                          if ( newText <> tText ) then aMember.text = newText
                        end SetDegreeChar
                        // scriptText of a scriptSyntax = #JavaScript movieScript member:
                        function jsReplace(inStr, strFind, strReplace){
                          // error check input
                          if(typeof(inStr)      != "string") { return inStr; }
                          if(typeof(strFind)    != "string") { return inStr; }
                          if(typeof(strReplace) != "string") { return inStr; }
                          // search-and-replace
                          re = new RegExp(strFind, "g");
                          return inStr.replace(re, strReplace);
                        • 9. Re: degree symbol displays as infinity on Mac.
                          fazstp Level 2
                          I wasn't sure if text formatting needed to be maintained so I opted to replace the chars within the member. If that isn't an issue then you will probably find Sean's solution to be quicker.
                          • 10. Re: degree symbol displays as infinity on Mac.
                            kar13 Level 1
                            fazstp,
                            I tried using your code but it doesn't seem to be having any effect. Please excuse my ignorance; I'm sure I'm doing something wrong....
                            I copy/pasted your code into a new script window. Should this be a #score, #movie, or #parent  scriptType?
                            Do I apply this directly to each textbox item? Do I apply it to a frame in the script channel? Do I put it in frame 1's script channel so it affects the entire movie?
                            Also, on PC the degree symbol is Alt0176. Do I need that 0 in the code you provided? Your code says numToChar( 176 )
                            Your code references "my text field". I'm trying to alter text Boxes, not fields. Does that matter?
                            Each of my text boxes already have individual member names. Is there a way to have this code affect whatever textbox it's applied to, rather than specifying a member name?  Text member of me .... or something like that?
                            Sorry if these are rudimentary questions.
                            Thanks for your help.
                            -Karen
                            • 11. Re: degree symbol displays as infinity on Mac.
                              kar13 Level 1
                              Hi Sean,
                              I tried implementing your code, but Director is giving me script errors.
                              It doesn't like this line:   // scriptText of a scriptSyntax = #JavaScript movieScript member:
                              I assumed the double hash was intended as a commented line, so I commented out the // lines in Director to test it.
                              Then I got a script error (Handler definition expected) on this line:    function jsReplace(inStr, strFind, strReplace){
                              I'm sure it's an error on my part.
                              Any idea what I'm doing wrong?
                              Would I apply this script to the individual text items in the score? Do I put it in the upper script channel somewhere?
                              Thanks for all your help.
                              -Karen
                              • 12. Re: degree symbol displays as infinity on Mac.
                                Like the comment says, the scriptText following should be in a movie script whose scriptSyntax is set to JavaScript. Do you understand what I mean by "movie script" and "JavaScript scriptSyntax"? It sounds to me like you have tried to compile it into a Lingo script.
                                • 13. Re: degree symbol displays as infinity on Mac.
                                  fazstp Level 2
                                  You could use this version in a behaviour (#score type) applied to the text fields. It should format the degree char on beginSprite.
                                  on beginSprite me
                                    SetDegreeChar( me )
                                  end beginSprite
                                  on SetDegreeChar me
                                      SearchAndReplace( me, sprite( me.spriteNum ).member, win_char, mac_char )
                                    else
                                      SearchAndReplace( me, sprite( me.spriteNum ).member, mac_char, win_char )
                                    end if
                                  end SetDegreeChar
                                  on SearchAndReplace me, text_member, search_string, replace_string
                                      return FALSE
                                    end if
                                      return FALSE
                                    end if
                                      return FALSE
                                    end if
                                      return FALSE
                                    end if
                                    start_char = 1
                                        exit repeat
                                      end if
                                    end repeat
                                    return TRUE
