3 Replies Latest reply on May 21, 2009 7:42 PM by YorFlexGuy
    public property and component instantiation order problem
    YorFlexGuy
      Hello everybody.
      I've been trying to tackle the instantiation flow of components, and do things the right way, but I seems to be running into problems.
      For example, I have a custom component, with some public properties variables exposed. I create my component and set my variables like this:
      //  PARENT
      btn = new ConditionBtn();
      btn.aXML = myXML;
      btn.addEventListener("change", answerChangeHandler);
      this.addChild(btn);
      And inside my component, I am trying to handle the instantiation like this:
      // CHILD COMPONENT
      private var isSelected:Boolean;
      //pre-initialize event handler
      private function preInitialize():void{
      //initialize event handler
      private function initialize():void{
          if(aXML.@selected == "true"){
                selected = true;
           }else{
                selected = false;
      //creation complete event handler
      private function creationComplete():void{
      This doesn't work though because when teh initialize event is fired, aXML shows as NULL when i debug. This doesn't make sense to me though because the initialize event is not fired until I call this.addChild from the parent, which is done AFTER i set the aXML value in my component so one would think the data should be there already.
      I tried moving the logic into the creationComplete hander but aXML is still null at that point. The workaround that i'm doing is creating another function which I call manually after I add it to the stage like this:
      // PARENT
      btn.aXML = myXML;
      this.addChild(btn);
      btn.bindManually();
      // CHILD COMPONENT
      public function bindManually():void{
                selected = true;
           }else{
                selected = false;
      Now this works, but it seems like a really bad practice. Isn't the whole point of the pre-init and initialize events is to let you setup your component beforehand so when it finally draws itself everything is setup and doesn't have to be re-setup?
      Am i doing something wrong?
