1 Reply Latest reply on May 19, 2009 11:52 AM by JP092372
    Flash and XML data loading issue
    JP092372
      I have this SWF that loads 2 XML files that controls 2 different areas of the SWF.  I am using this code because I have stacked layers and when this was 2 seperate SWFs I couldn't use the SWFObject because of the wmode quirk in FF.  So my issue is when you first load this it seems to only load the slideshow (left side) and part of the right menu and then on refresh it loads the rest of the menu - how do I get it to load everything at once?  I have attacehed all of my files.
      <div id="LargeFlashContainerFlashMenu">
                              <script language="javascript">
                                    if (AC_FL_RunContent == 0) {
                                         alert("This page requires AC_RunActiveContent.js.");
                                    } else {
                                         AC_FL_RunContent(
                                              'codebase', 'http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,0,0',
                                              'width', '940',
                                              'height', '265',
                                              'src', 'JGSB_HeaderRightNav_v05',
                                              'FlashVars', 'strNavContentXML=BICMenu.xml&strShowContentXML=settings.xml',
                                              'quality', 'high',
                                              'pluginspage', 'http://www.macromedia.com/go/getflashplayer',
                                              'align', 'middle',
                                              'play', 'true',
                                              'loop', 'true',
                                              'scale', 'showall',
                                              'wmode', 'transparent',
                                              'devicefont', 'false',
                                              'id', 'JGSB_HeaderRightNav_v05',
                                              'bgcolor', '#000000',
                                              'name', 'JGSB_HeaderRightNav_v05',
                                              'menu', 'true',
                                              'allowFullScreen', 'false',
                                              'allowScriptAccess','sameDomain',
                                              'movie', 'JGSB_HeaderRightNav_v05',
                                              'salign', ''
                                              ); //end AC code
                               </script>
                               <noscript>
                                         <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,0,0" width="940" height="265" id="JGSB_HeaderRightNav_v05" align="middle">
                                              <param name="allowScriptAccess" value="sameDomain" />
                                              <param name="allowFullScreen" value="false" />
                                              <param name="movie" value="JGSB_HeaderRightNav_v05.swf" />
                                              <param name="FlashVars" value="strNavContentXML=BICMenu.xml&strShowContentXML=settings.xml" />
                                              <param name="quality" value="high" />
                                              <param name="wmode" value="transparent" />
                                              <param name="bgcolor" value="#000000" />
                                              <embed wmode="transparent" src="JGSB_HeaderRightNav_v05.swf" quality="high" bgcolor="#0099cc" width="940" height="265" name="JGSB_HeaderRightNav_v05" align="middle" allowScriptAccess="sameDomain" allowFullScreen="false" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" />
                                         </object>
                               </noscript>
                     </div>
