4 Replies Latest reply on May 21, 2009 11:32 PM by elaine montoya
    Cutting out animation
    anura lochan
      I would like to cut a portion of an animated video and super impose it over some home movies. I want to select the character(s) only, no back ground. For example my grand daughter loves jungle book and I would like to cut out King Louie and have him move about on stills and video of her that I am assembling for her birthday.  I have been told that this is something I can do with AE, but I have not figured out how.  Anyone have any suggestions?
        • 1. Re: Cutting out animation
          Todd_Kopriva Level 8
          What you're describing sounds like a typical rotoscoping task.
          • 2. Re: Cutting out animation
            anura lochan Level 1
            Thank You Todd,
            I'm using the links and trying to learn how to do this
            Dean
            • 3. Re: Cutting out animation
              David Wigforss-Hv1BNN Level 2
              I'm not familiar with the character, but the nice thing with 2d animated characters, you also might be able to create a matte to make your life MUCH easier.
              What sometimes works for me, is creating a duplicate copy of the footage, and linear color keying the character.  Start by keying out the skin.  Then duplicate that keying effect  (not the entire layer) and select another color of the character.
              Try to do that for as much as you can, without it selecting areas of the background, especially close to the character.  You might be able to then create a garbage mask to clear out any bits of the bg still left.
              Also, use the matte effects to expand the keyed out character, so it includes the ink line.  Then use that as an alpha track matte for your original footage.
              Roto is a pain, but usually that's what's required.  I suggest stabilizing the shot first, if there's any camera moves on it.  And then depending on how much the character is animated, create multiple masks for different sections of the character.
              -Dave
              (CG artist on Dora The Explorer)
              • 4. Re: Cutting out animation
                elaine montoya Level 3
                I don't know what you experience level with After Effects is, but this is something that can be done. But, if the person who suggested After Effects to you gave you the impression is would be 'easy to do with After Effects' (ie, push a button and remove the background), then they have mislead you.
                The suggestions provided are good ones, and should work to achieve your objectives.
                If you are fairly experienced with After Effects, learning rotoscope techniques won't be that difficult for you.
                On the other hand, if this is your first After Effects project, you're in for an intensive learning experience
                Good luck!
                elaine
                p.s. also be aware of licensing/copyright issues (ie King Louie) if you plan to use your work in any public way.
