0 Replies Latest reply on May 19, 2009 2:45 PM by rfrishbe
    [svn:fx-trunk] 7087: VideoPlayer bug fixes:
    rfrishbe Level 3
      Revision: 7087
      Author:   rfrishbe@adobe.com
      Date:     2009-05-19 13:44:50 -0700 (Tue, 19 May 2009)
      Log Message:
      - Forgot to dispatch the ready event
      - The properties on videoplayer that are proxied from videoelement now take into account the correct defaults
      - We deal with null or empty string sources better by clearing the video and closing the connection to the net stream.  It looks like play() won?\226?\128?\153t take in any arguments?\226?\128?\148at that point, I?\226?\128?\153ll clean up this code around dealign with startTime and duration as well as refactoring some of this ?\226?\128?\156close?\226?\128?\157 the connection code.
      - PopUpAnchor pushes the concatenated color matrix, similar to the concatenated transform matrix.  This will need to undergo any changes based on Chet?\226?\128?\153s findings.
      - Adding enabling/disabling support.  This change is dependent on Jason?\226?\128?\153s SKinnableComponent change around enabling/disabling.
      - Skin changes in VideoPlayerSkin and volume bar/volumebarmutebutton.
      QE Notes: -
      Doc Notes: -
      Bugs: SDK-21185, SDK-21187, SDK-21015, SDK-20971, SDK-20969, SDK-20928, SDK-21098, SDK-20986, SDK-20947, SDK-20939, SDK-20934, SDK-21014
      Reviewer: Deepa
      tests: checkintests
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21185
          http://bugs.adobe.com/jira/browse/SDK-21187
          http://bugs.adobe.com/jira/browse/SDK-21015
          http://bugs.adobe.com/jira/browse/SDK-20971
          http://bugs.adobe.com/jira/browse/SDK-20969
          http://bugs.adobe.com/jira/browse/SDK-20928
          http://bugs.adobe.com/jira/browse/SDK-21098
          http://bugs.adobe.com/jira/browse/SDK-20986
          http://bugs.adobe.com/jira/browse/SDK-20947
          http://bugs.adobe.com/jira/browse/SDK-20939
          http://bugs.adobe.com/jira/browse/SDK-20934
          http://bugs.adobe.com/jira/browse/SDK-21014
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Panel.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/PopUpAnchor.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Slider.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/VideoElement.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerVolumeBarMute ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerVolumeBarSkin .mxml
