1 Reply Latest reply on Sep 18, 2008 11:34 PM by kglad
    Clear Cache? (k)
    xparrot_dude Level 1
      I have a flash movie that seems to choke at a certain point in the movie. I'm pretty confident it is a caching issue. My reason for this theory is if I remove several photos prior to the hanging photo, the movie plays fine.
      http://www.pbjewelrydesigns.com/index2.html
      I sped up the movie to get to the hangup point faster. You'll notice when it hits 24 of 38 it stops fading and just goes right to the next frame. I have triple checked my code and it is the same throughout.
      I use the tween class to do the fade. Here is the code I am using:
        • 1. Re: Clear Cache? (k)
          you can't force the cache to clear and that's not a cache problem. you probably have a problem (re)using teh same tween name for your tweens.
          try using different names for each tween and see if the problem resolves.
          p.s. that diamond ring is a design-copy of a tiffany commissioned schlumberger diamond ring.
