2 Replies Latest reply on May 20, 2009 2:35 PM by Roy Marshall
    [JS][CS3] Copy-Paste
    Roy Marshall Level 1
      Hi
      I am pretty sure this has been asked before, but I cannot find it in the forum.
      Is there a way to include in the JS a copy method to select an image, and paste into a text frame as an inline graphic?  I have placed images as inline graphics before with JS, but I was using a path to a folder.  In this new case, I cannot point to a folder for the image as the image is not on an attached volume, I am carrying out this script on a document already populated, but with missing links.
      I hope this makes sense to someone!
      Cheers
      Roy
        • 1. Re: [JS][CS3] Copy-Paste
          Dave Saunders Level 4
          Hi Roy,
          It can indeed be done that way. You just have to select the insertion point (and I mean select in this case) before issuing the paste.
          I prefer to use a library to achieve this goal, along these lines (this code assumes I already have a library open):
                var myTableTab = myDoc.textFrames.item("TableTab").getElements()[0];
                // Move TableTab inline using library for temp storage
                var temp = projLibrary.store(myTableTab);
                temp.placeAsset(myStory.paragraphs[tableLoc].insertionPoints[0]);
                temp.remove();
                myTableTab.remove();
          An advantage of this approach is that it leaves the clipboard unchanged.
          Dave
          • 2. Re: [JS][CS3] Copy-Paste
            Hi Dave.
            The library method makes sense, I will give it a go when I get a mo.
            Cheers again,
            Roy
