0 Replies Latest reply on May 19, 2009 11:16 PM by GordonSmith
    [svn:fx-trunk] 7113: Added [RichTextContent] metadata to the 'content' property of RichText, RichEditableText, and TextArea.
    GordonSmith Level 4
      Revision: 7113
      Author:   gosmith@adobe.com
      Date:     2009-05-19 22:16:39 -0700 (Tue, 19 May 2009)
      Log Message:
      Added metadata to the 'content' property of RichText, RichEditableText, and TextArea.
      This metadata tells the MXML compiler to disable some of its default interpreation of the value specified for the 'content' property. Normally, for properties of type Object, it assumes that things looking like numbers are numbers and things looking like arrays are arrays. But hould set it to the String "[1]", not the Array . However, {...} continues to be interpreted as a databinding expression, and @Resource(...), @Embed(...), etc. as compiler directives.
      Similar metadata on the mxmlChildren property in TLF's FlowGroupElement and SpanElement classes causes the same rules to apply within
      , etc.
      QE Notes: None
      Doc Notes: None
      Bugs: Part of SDK-17748 and SDK-18877
      Reviewer: Peter
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-17748
          http://bugs.adobe.com/jira/browse/SDK-18877
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/TextArea.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/RichText.as
