2 Replies Latest reply on Sep 15, 2008 12:51 PM by Newsgroup_User
    Tree control - How to get the full path of selected Item in tree control
    Thamizhannal
      I am Flex newbie. When the user clicks the particular item in the tree control I just wanted to get it name along with it's full parent.
      Here is my XML
      var dirXML:XML=<root basename="/home/tcegrid">
      <Directories>
      <Dir Name=".autosave" />
      <Dir Name=".emacs.d" />
      <Dir Name="AnsysDistributed">
      <Dir Name="opt"/>
      <Dir Name="root" />
      </Dir>
      <Dir Name="postgres"/>
      <Dir Name="FineTurbo"/>
      <Directories>
      </root>
      The above XML is data provider for Tree control. When the user clicks the Dir Name called opt. I wanted it absolute path in XML. say Directories.Dir.Dir.@Name is opt
      Can any one tell me how to get this?
        • 1. Re: Tree control - How to get the full path of selected Item in tree control
          ntsiii Level 3
          There is no built-in ancestor functionality in e4x.
          You will need to use the "parent()" method in a loop to move back up the ancestor chain until you hit the root, at which point parent() will be null.
          Tracy
          • 2. Re: Tree control - How to get the full path of selected Item in tree control
            Level 7
            "Thamizhannal" <webforumsuser@macromedia.com> wrote in message
            news:gam9q8$4es$1@forums.macromedia.com...
            >control
            > Here is my XML
            > <Directories>
            > <Dir Name="opt"/>
            > <Dir Name="root" />
            > </Dir>
            > <Directories>
            > </root>
            > Dir
            loop until the parent() property of the XML node is empty.
            HTH;
            Amy
