3 Replies Latest reply on May 23, 2009 2:10 PM by Averdahl
    how do i capture from blackmagic?
    jlb6503596
      i've got a blackmagic decklink studio card on a windows vista machine. i'm trying to capture footage within premiere but it can't see my video feed. i know i've got it hooked up correctly because the blackmagic media express program shows me my incoming video, and i can record it and play it back.
      whenever i open up the capture window, it tells me my capture device is offline. within the menu options though, it does tell me that i'm hooked up via sony rs-422 protocol. my port is com1. not sure what else i'm missing, but i still can't see me video.
        • 1. Re: how do i capture from blackmagic?
          Bill Gehrke Adobe Community Professional & MVP
          That is a BlackMagic question.  As far as I know Premiere only captures via the Firewire port.  If as you say you can record your video then find a way to just import the the file.
          What format is the captured file?
          Does Blackmagic have a format that Premiere can import?
          Does BlackMagic have an import plugin for Premiere?
          RS 422/Com 1 buzzwords indicate slow speed serial ports that probably are just control signals not at all compatible with video signals.
          • 2. Re: how do i capture from blackmagic?
            jlb6503596 Level 1
            well i called blackmagic and asked them about capturing within premiere. they said that it was an adobe question and that it should be possible. but if it only captures via firewire i suppose that makes sense.
            as for the format it records in, i'd have to check but i'm sure it'll be compatible with premiere. i was just hoping that capturing sdi would be possible in order to keep it all in one program. final cut pro can do it, i just assumed adobe could as well.
            • 3. Re: how do i capture from blackmagic?
              Averdahl Level 3
              Mac or Pc?
              If Mac, Blackmagic Design has not released drivers for Pr CS4 yet.
              If PC, press F5 > Click on Settings > Click on Edit > Change Capture format from whatever to Blackmagic Capture > Click on Properties > Select what you want to capture, Video Standard and Video Format > Click on OK.
              If it does not work, go to the Control Panel > Click on Decklink > Make sure that everything is set correctly. Everything *must* match, if not = no capture in Pr.
              /Roger
