3 Replies Latest reply on May 22, 2009 4:40 AM by mack_
    CF8 & ASP.NET - Auto login to ASP app via CF
    stsemrau Level 1
      Hello everyone I hope someone can provide me with the information I'm looking for :/
      My situation is this - I have inheritted a CF5 / FB3 application that is now in the process of being revamped and is currently running on CF8.
      I have also inheritted an application that is a mix of CF5 and ASP as well as an application that is completely ASP.NET 2.0.
      The customer, for the time being, would like to be able to log into the CF application and have their information automatically passed into the ASP.NET application so they don't have to log in twice.
      I have never worked with ASP / ASP.NET before and I'm looking for a way to do this.
      The ASP.NET application appears to be using asp:Login container/functionality.
      Thanks in advance,
        • 1. Re: CF8 & ASP.NET - Auto login to ASP app via CF
          mack_ Level 3
          One solution is to inform the ASP application that the client has
          logged in. You can do this by sending the ASP app a secure token after
          the client is logged in (by security token I mean for example a string
          encrypted with a password that is known to both applications). On the
          ASP side you can decrypt the string (that can contain the user ID or
          email) and log in the user automatically.
          • 2. Re: CF8 & ASP.NET - Auto login to ASP app via CF
            stsemrau Level 1
            I see what you are saying - however I don't have the source files at this time for the ASP.NET application so I don't have the ability to recompile the application.
            The ASP.NET application is using the ASP.NET Login control set.
            The scenario is this:
            • The CF application uses the standard web form for username and password.
            • User logs into the CF application
            • User navigates around application
            • User reaches a page that needs to ALSO present (in lne) information from the ASP.NET application
            • ASP.NET application requires a log in before navigation within the application
            This is the point at which I want to, behind the scenes, pass the username and password to the ASP.NET application so within the iframe the user is not seeing the Log In page of the ASP.NET application.
            I have tried using cfhttp with little success at this point trying to get past the ASP.NET login screen.
            • 3. Re: CF8 & ASP.NET - Auto login to ASP app via CF
              mack_ Level 3
              This works if the CF and ASP applications are on the same domain (for
              example site.com): you cfhttp the username and password to the asp
              application, get the cookies from the response and then set those
              cookies on the site.com domain (so the browser will send the cookies
              next time he connects to your site). This will not work if the ASP
              application associates a cookie with an IP (because the login request
              will be made from your CF server address or localhost and the client
              will send the cookies from a different IP).
