0 Replies Latest reply on May 20, 2009 3:39 PM by Jason Szeto
    [svn:fx-trunk] 7155: Line bug fixes when using gradient strokes
    Jason Szeto Level 3
      Revision: 7155
      Author:   jszeto@adobe.com
      Date:     2009-05-20 14:39:39 -0700 (Wed, 20 May 2009)
      Log Message:
      SDK-21272 - Lines with gradient (LinearGradientStroke) draw as solid color if perfectly vertical / horizontal
      StrokedElement was not taking the stroke weight into account when passing the bounds to the stroke. The gradient strokes rely on the bounds to help them transform the gradient to fit the shape of the stroke.
      SDK-21274 - Line with gradient stroke does not draw properly
      This bug occurs when the Line has a non-zero x and/or y values and is sharing a DisplayObject. StrokedElement was passing the stroke the measuredX and measuredY position as part of the bounds. Instead, I've changed it to pass in drawX + measuredX and drawY + measuredY which accounts for the drawing offset position.
      QE Notes: Test Line w/ gradient strokes
      Doc Notes: None
      Bugs: SDK-21272, SDK-21274
      Reviewer: Evtim
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21272
          http://bugs.adobe.com/jira/browse/SDK-21274
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/StrokedEleme nt.as
