Revision: 7163
Author: aharui@adobe.com
Date: 2009-05-20 19:19:55 -0700 (Wed, 20 May 2009)
Log Message:
Initial checkin of frame 1 cleanup. In an RSL linkage, more classes will now come from the RSL because they are no longer needed in frame 1, and the size of the application SWF will be smaller.
QE Notes: None
Doc Notes: Maybe. All new classes should be undocumented, but it might be worth checking that and any changes to interfaces
Bugs:
Reviewer: darrell
tests: checkintests mustella/MarshallPlan
Modified Paths:
flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/Window.as
flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/WindowedSystemManager.as
flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/Window.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Application.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/RichEditableText.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/RichText.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/SimpleText.as
flex/sdk/trunk/frameworks/projects/framework/src/FrameworkClasses.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Alert.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ColorPicker.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBox.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateField.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Menu.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/MenuBar.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/PopUpButton.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/alertClasses/AlertForm.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridColumn.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridItemRenderer.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListItemRenderer.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/TileListItemRenderer.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/treeClasses/TreeItemRenderer.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Application.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/EmbeddedFont.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/EmbeddedFontRegistry.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IEmbeddedFontRegistry.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ISWFBridgeGroup.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ISWFBridgeProvider.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ResourceModuleRSLItem.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/SWFBridgeGroup.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ScrollControlBase.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextFormat.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/events/EventListenerRequest.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexEvent.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/events/RSLEvent.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/CursorManagerImpl.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/FocusManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/IFocusManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/ISystemManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/LayoutManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/PopUpManagerImpl.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManagerGlobals.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManagerProxy.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/ToolTipManagerImpl.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/EventProxy.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/messaging/config/LoaderConfig.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/preloaders/DownloadProgressBar.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/preloaders/Preloader.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/resources/ResourceManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/resources/ResourceManagerImpl.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/CSSStyleDeclaration.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
flex/sdk/trunk/frameworks/projects/framework_textLayout/src/mx/core/UITLFTextField.as
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
flex/sdk/trunk/mustella/MustellaResultsParser.java
flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/FrameworkSwcDependencyRules.java
flex/sdk/trunk/tools/dependencychecker/frameworkSwcExceptionsList.txt
Added Paths:
flex/sdk/trunk/frameworks/projects/framework/src/mx/events/Request.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/IActiveWindowManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/IMarshalSystemManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/ISystemManagerChildManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/PopUpData.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/marshalClasses/
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/marshalClasses/CursorManagerMarshalMixin.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/marshalClasses/DragManagerMarshalMixin.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/marshalClasses/FocusManagerMarshalMixin.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/marshalClasses/MarshalPopUpData.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/marshalClasses/PopUpManagerMarshalMixin.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/marshalClasses/ToolTipManagerMarshalMixin.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/ActiveWindowManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/ChildManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/MarshallPlan.as
