1. Re: var this doesn't exist in 3d AS 3.0 xml data...
kglad May 20, 2009 10:30 PM (in response to the_missing_link)what are you trying to say?
2. Re: var this doesn't exist in 3d AS 3.0 xml data...
the_missing_link May 21, 2009 8:30 AM (in response to kglad)I just figured out what was wrong. In adobe cs3 when you copied a object as
actionscript 3.0 it would produce xml with a variable called this at the
beginning. I wrote a script in cs4 relying on the variable this not knowing
that adobe had made changes to the copied object as actionscript 3.0 xml
ommitting the variable this. Oh well.
3. Re: var this doesn't exist in 3d AS 3.0 xml data...
SwapnilVJ May 21, 2009 8:38 AM (in response to the_missing_link)I am feeling stupid reading this....
In CS4 also AS3.0 is the same what you have before [except for the changes due to flash payer 10]....Isn't it kglad?
Not clear with what is being asked exactly?
4. Re: var this doesn't exist in 3d AS 3.0 xml data...
Greg Dove May 21, 2009 3:09 PM (in response to SwapnilVJ)I suspect- but don't know for sure - that it might be related to Copy motion as XML (or whatever that feature is called - I have not used it myself)
5. Re: var this doesn't exist in 3d AS 3.0 xml data...
the_missing_link May 21, 2009 8:06 PM (in response to Greg Dove)Thank you Greg! Yes that's what I'm talking about. My script is so messed up
though that I will have to start from scratch. Oh I would like to point out
that the xml has been changed between cs3 and cs4. It may not be that
noticable but it has been changed.
