3 Replies Latest reply on May 22, 2009 1:03 AM by Kebaya Mwamba
    Creating XML Schemas: How to?
    Kebaya Mwamba
      How do i create XML schemas? Which programs can i use? I'd like one that has wizards. Thank you.
        • 1. Re: Creating XML Schemas: How to?
          Hodmi Level 4
          This is beyond the scope of this forum, but you may want ot have a look at Altova's XMLSpy or Liquid's XML Studio.  I personally like XMLSpy but that's a personal choice.  Of course there are many others.
          • 2. Re: Creating XML Schemas: How to?
            Steve L Walker Level 5
            For creating a schema AFTER creating a PDF form, a common procedure is as follows:
            1) in LiveCycle Designer ES, save the form as a static or dynamic PDF
            2) open the form in Acrobat
            3) export the form data as xml (Forms > Manage Data > Export Data)
            4) in XMLSpy open the xml and generate a schema
            Note
            1) do not fill the form in Acrobat before exporting the data (XMLSpy will use the data as the basis for creating schema restrictions)
            2) I personally do not like the way XMLSpy generates schema (it VERY verbose) so I ultimately edit the schema, but it is easier than starting from scratch
            Steve
            • 3. Re: Creating XML Schemas: How to?
              Kebaya Mwamba Level 1
              XML Spy...here i Come!!!!!
